Displaying the Check Engine
This function requires the tenant permission or the te_admin role in IAM 3.0.
- Access CodeArts Check from the service portal.
- Click the Config Center tab and enable Show Engine in Advanced settings. Figure 1 Displaying the check engine
By default, the engine information of CodeArts Check is not displayed. After Show Engine is enabled, the engine information is displayed on the task issue export files, code issue export files, rule export files, model set, custom rule set creation, custom rule set management, rule details, rule description, issue context, and issue help pages.
