Configuring Tenant-Level Check Languages
Users with the permissions of te_admin, tenant space administrator, and tenant space owner can configure the required languages and file name extensions (max. 50, including default extensions). After the configuration is complete, the languages will be used in Creating a Task.
- Access CodeArts Check from the service portal.
- On the CodeArts Check page, choose Config Center > Language.
- In the language list on the right of the page, the preset languages (all letters in uppercase) and their file name extensions (separated by commas) are displayed.
- In the Operation column, you can perform the following operations:
- Click
to modify a custom file name extension. - Click
to delete a custom file name extension. The system languages cannot be deleted.
- Click
