Help Center/ CodeArts Check/ User Guide/ Configuring Project-Level Notifications
Updated on 2026-09-30 GMT+08:00
CodeArts Check allows you to configure project-level notifications. The configuration takes effect for all check tasks in the project.
This feature is supported only in the AP-Singapore region.
Finding the Configuration Entry
  1. Access CodeArts Check through a project.
  2. On the menu bar, choose Settings > General > Notifications.
Configuring System Messages
When an event occurs, the system sends a message to the specified recipient.
  1. Click the Direct Message tab.
  2. Select CodeArts Check.
  3. Configure the recipients (including the creator and operator) of each event and whether to enable the notification function for these events.
Configuring Email Notifications
When an event occurs, the system sends a message to the specified recipient by email. The recipients will receive emails only if they have enabled email notifications and set a valid email address.
  1. Click the Email tab.
Configuring WeCom Notifications
When an event occurs, the system sends a message to the specified WeCom group through the WeCom robot.
  1. Click the WeCom tab.
  3. Set parameters by referring to the following table.
    Table 1 WeCom parameters
    URL
    To obtain the URL: (Take the mobile client as an example.)
    1. Start the WeCom client, select the group chat to receive messages, and click the three-point button in the upper right corner.
    2. Choose Group Robot > Add > New.
    3. Enter the robot name and click Add.
    4. Click Copy next to the Webhook text box to obtain the WeCom webhook URL.
    Event Type
    Set the event type for notifications.
    • All: The recipients will be notified of all task execution results.
    • Gate Result Passed: The recipients will be notified only when the check task execution result is passed.
    • Gate Result Failed: The recipients will be notified only when the check task execution result is failed.
    Notification Content
    Select the check result, gate result, number of issues, redirection link, operator, or completion time.
    @User IDs
    Enter WeCom user IDs. Use semicolons (;) to separate them.
    @Mobile Numbers
    Enter mobile numbers. Use semicolons (;) to separate them.
Configuring DingTalk Notifications
When an event occurs, the system sends a message to the specified DingTalk group.
  1. Click the DingTalk tab.
  3. Set parameters according to the following table.
    Table 2 DingTalk parameters
    URL
    To obtain the URL:
    1. Go to the DingTalk group, choose Group Settings > Group Assistant, and add a robot (select Custom).
    2. Enter the robot name, select a group, and complete the security settings. (Select Additional Signature and click Copy next to the text box to obtain the key.)
    3. After reading and agreeing to the agreement, click Finished. Click Copy next to the webhook text box to obtain the DingTalk webhook URL.
    4. Select DingTalk, enter a webhook URL, and click Test to ensure that the webhook URL is available.
    Event Type
    @User IDs
    Enter DingTalk member IDs. Use semicolons (;) to separate them.
    @Mobile Numbers
    Secret
    Enter the DingTalk signing secret.
Configuring Feishu Notifications
When an event occurs, the system sends a message to the Feishu group chatbot.
  1. Click the Feishu tab.
    Table 3 Feishu parameters
    URL
    Feishu robot URL, which must start with http:// or https://. Example: https://xxxxxx
    Event Type
    @User IDs
    Enter the user IDs receiving notifications. Use commas (,) to separate multiple user IDs.
    Secret
    (Optional) Enter this parameter only when you have enabled security settings for the Feishu custom robot.
  4. After the configuration, click Save. A message is displayed, indicating that the settings are saved.
