Help Center/ CodeArts Check/ User Guide/ Working with CodeArts Check
Updated on 2026-09-30 GMT+08:00
CodeArts Check is a cloud-based service that checks code. With years of experience in automatic static check and enterprise application, CodeArts Check provides rich check services on code style, common quality, cyber security risk, and other elements. It also includes comprehensive check reports, convenient bug handling, and many other efficient, easy-to-use functions for enterprises to effectively improve code quality.
Table 1 Process description
Process
Purchasing CodeArts Check
Purchase CodeArts Check.
Configuring Project-level Role Permissions
Access the CodeArts Check homepage and configure project-level permissions.
Creating a Task
Create tasks from different repositories.
Configuring a Task
Modify or configure existing check tasks.
Executing a Task
Execute a check task to identify issues in the source code.
Viewing Check Results
View the check results and fix code issues after a code check task is complete.
