Help Center/ CodeArts Check/ User Guide/ Configuring a Task/ Configuring a Scheduled Task
Updated on 2025-07-31 GMT+08:00
You can set the execution plans of a code check task as required to periodically execute the check task for the default branch.
It is advised to configure this for tasks in non-pipeline mode.
The interval on the current day must be longer than 5 minutes.
Configuring an Execution Plan
  1. Access CodeArts Check.
  2. Go to the task page. In the task list, click a task name.
  3. On the task details page, choose Settings > Execution Plans.
  4. Enable Scheduled Check and set the automatic execution time.
    Figure 1 Configuring an execution plan
  5. Click Save.
