- What's New
- Function Overview
- Getting Started
User Guide
- Working with CodeArts Check
- Purchasing CodeArts Check
- Configuring Project-level Role Permissions
- Creating a Task
- Configuring a Task
- Executing a Task
- Viewing Check Results
- Querying Audit Logs
- Reference
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
Task Management
- Creating a Check Task
- Deleting a Check Task
- Querying Tasks
- Executing a Check Task
- Stopping a Check Task
- Querying the Status of a Task
- Querying Historical Check Results
- Querying Selected Rule Sets of a Task (Version 2)
- Querying Selected Rule Sets of a Task (Version 3)
- Querying the Check Parameters of a Rule Set (Version 2)
- Querying the Check Parameters of a Rule Set (Version 3)
- Configuring the Check Parameters of a Task
- Modifying the Rule Set in a Task
- Querying Check Failure Logs
- Obtaining the Directory Tree of a Task
- Ignoring Directories of a Task
- Querying Advanced Configurations of a Task
- Configuring Advanced Configurations for a Task
- Issue Management
- Rule Management
Task Management
- Application Examples
- Appendixes
- Description
General Issues
- Why Am I Told that a Task Is Running and I Should Try Again Later?
- Why Am I Told that I Don't Have Sufficient Permissions and I Should Check and Try Again?
- Why Am I Told that Cppcheck Cannot Tokenize the Code Correctly?
- Why Am I Told that No Dependency Exists in the Maven Repository?
- Why Am I Seeing Error CC.00070400.500?
- Why Don't I Have Enough Permissions When Clicking a Task Name?
- Why Does a Project with WPF in C# Fail?
- Why Is No Data Displayed After a Task Is Complete?
- Why Does a TypeScript Task Fail with a 404 Error in the Log?
- API Issues
General Issues
- Videos
Querying Audit Logs
Cloud Trace Service (CTS) records operations on CodeArts Check for query, audit, and backtrack.
Operations Recorded by CTS
Operation |
Resource Type |
Event |
Creating a task |
task |
create |
Modifying a task |
task |
modify |
Deleting a task |
task |
delete |
Executing a task |
job |
create |
Canceling a task |
job |
modify_job |
Favoriting a task |
followingTask |
create_followingTask |
Unfavoriting a task |
followingTask |
delete_followingTask |
Modifying rule set information |
ruleset |
modify_ruleset |
Modifying rules in a rule set |
ruleset |
modify_ruleset |
Deleting a rule set |
ruleset |
delete_ruleset |
Setting a rule set as default |
ruleset |
set_default_ruleset |
Exporting a rule set |
ruleset |
export_ruleset |
Exporting issues |
defectExcel |
export_defectExcel |
Downloading issues |
defectExcel |
downloadAndExport_defectExcel |
Modifying an issue status |
issueStatus |
update_issueStatus |
Changing the owner |
issueOwner |
update_issueOwner |
Modifying an issue comment |
issueComment |
update_issueComment |
Viewing Audit Logs
Query CodeArts Check traces on the CTS console. For details, see Viewing Audit Logs.
