Updated on 2026-06-24 GMT+08:00
Creating an Agent Pool
You can use built-in or custom executors to perform check, build, deployment, pipeline, and API test tasks in CodeArts.
Agent pools are used to connect custom executors. You can add your own execution resources to an agent pool so that you can use them to execute tasks. Agent pools help improve efficiency and remove dependency on public execution resources.
  1. Go to the CodeArts homepage.
    1. Log in to the CodeArts console, click , and select a region where you have enabled CodeArts.
    2. Click Go to Workspace.
      If your account uses the old billing mode (see Old Billing Modes), click Access Service.
  2. Click the username on the top navigation bar and choose All Account Settings.
  3. Choose Agent Pool > Agent Pool. The resource pool list is displayed.
  4. Click Create Pool, configure the agent pool, and click Save.
    A new record is displayed in the list.
    Table 1 Creating an agent pool
    Pool Name
    The name of the agent pool. Enter a maximum of 50 characters. Digits, letters, periods (.), underscores (_), and hyphens (-) are supported.
    Pool Type
    Supported pool types:
    • LINUX: Tasks are executed on a Linux VM.
    • LINUX_DOCKER: A Linux Docker container is started and tasks are executed in the container.
    • WINDOWS: Tasks are executed on a Windows VM.
    • MAC: Tasks are executed on a macOS VM.
    Describe the agent pool. Enter a maximum of 1,024 characters.
    Optional. Configure it if you need to describe the agent pool.
    This pool can be used by all users of the current account.
    Optional. If this parameter is selected, this agent pool can be used by all users of the current account.
Managing an Agent Pool
  3. Choose Agent Management > Agent Pool.
  4. Locate the agent pool you want to manage, and perform the operations listed in the table below as needed.
    Table 2 Managing an agent pool
    Operation
    Modifying agent pool basic information
    Click in the Operation column. In the displayed dialog box, modify the pool name and description, and click Save.
    The modified agent pool information is displayed in the list.
    Setting pool administrators
    1. Click in the Operation column. The Permissions tab is displayed.
    2. Set administrators as needed.
      • Click Add next to Administrators, select users from the drop-down list, and click .
      • To remove the administrator role of a user, click next to the username.
      The modified administrators are displayed.
      Figure 1 Setting administrators
    Setting pool users
    2. Set users as needed.
      • Click the switch to set all users in your account as users of the agent pool.
      • Click Add next to Projects, select a project name from the drop-down list box, and click to set all members in the selected project as agent pool users.
      • To cancel the authorization for members in a project, click next to the project name.
      The modified information is displayed.
      Figure 2 Setting pool users
    Deleting the agent pool
    WARNING:
    The deletion cannot be undone. Exercise caution when performing this operation.
    Click in the Operation column. In the displayed dialog box, click Yes.
    The deleted agent pool is no longer displayed in the list.
    Setting notification rules
    1. In the agent pool list, click the name of the target pool to go to the agent list page.
    2. Click the Notifications tab. Enable or disable notifications for the following event types:
      • Create agent
      • Delete agent
      • Disable agent
      • Enable agent
      • Bring agent offline
      • Bring agent online
      The modified notification rules are displayed.
