Updated on 2025-09-23 GMT+08:00
Importing Users from Another Project
If your account has multiple projects, you can import members of one project to another.
This section uses projects X and Y as an example. You can add the members of project X to project Y.
  1. Go to the CodeArts homepage.
    1. Log in to the CodeArts console, click , and select a region where you have enabled CodeArts.
    2. Click Go to Workspace.
      If your account uses the old billing mode (see Old Billing Modes), click Access Service.
  2. Click the target project name to go to the project.
  3. In the navigation pane, choose Settings > Members.
  4. Click the Member View tab, click Add Members, and select From Another Project.
  5. In the displayed dialog box, select a project from the Project drop-down list. Members of the selected project are displayed.
  6. Select users, select a role from the Role drop-down list for each user, and click Save.
    Figure 1 Importing users from another project
    The new members are displayed in the list.
Helpful Links
