Help Center/ CodeArts Repo/ User Guide/ Hierarchical Repository Management/ Managing Repository Groups/ Configuring the Merge Request Template of a Repository Group
Updated on 2025-09-23 GMT+08:00
Table 1 Constraints on configuring merge request templates
Item
Package constraint
Only available for CodeArts Repo professional edition and CodeArts.
Permission constraint
You need to have the configuration permission. You can go to the homepage of the repository group to be configured, click Settings in the navigation bar, choose Security Management > Permissions, and check whether you have the set permission of the repository group.
If you do not have the permission, see Configuring a Repository Group's Permissions.
  1. As shown in the following figure, go to the repository group Test_Group to be configured.
  2. Click Settings in the navigation bar and choose Template Management > MR Templates in the left navigation pane.
  3. Click Create MR Template and enter the configuration information by referring to Procedure.
    After configuring the merge request template, view the configuration result by referring to Helpful Links.
