Help Center/ CodeArts Repo/ User Guide/ Managing Member Permissions/ Configuring Project-Level Permissions
Updated on 2026-06-24 GMT+08:00
Scenario Overview
Project-level repository permissions are vital for role-based access control in CodeArts Repo, affecting all associated resources in a project. The configuration is a key step to secure access to project code resources and boost team collaboration and efficiency.
This section describes the constraints and detailed steps for setting project-level repository permissions, guiding users with the necessary access to configure and manage roles effectively.
  • The project manager and other users with management permissions can modify the default operation permissions of different roles in the project on this page.
  • If the repository's visibility is set to read-only for project members, then all project members can view other resources except for the settings.
  • If the repository's visibility is set to read-only for tenant members, all tenant members can view other resources except for the settings.
  • If the repository's visibility is set to read-only for all visitors, then all visitors can view all resources except for the settings.
  1. Log in to the CodeArts Repo homepage. In the navigation pane on the left, choose Settings > Permissions. The Permissions page is displayed.
  2. Select the corresponding Role > CodeArts Repo, and click Edit to configure permissions.
    You can click in the Role column to create a role. Do not name the new role the same as a system role. You can copy the permissions of an existing role to the new role or select and add permissions to it as required.
