MR Evaluation
Overview
You can configure this feature to evaluate MRs by dimension on the merge request details page.
Item |
Description |
Package constraint |
If your package is the professional or enterprise edition, you can configure the MR evaluation. |
Permission constraint |
You must have the set permission to configure MR evaluation for the repository. For details, see Configuring Repo-Level Permissions. |
Setting MR Evaluation
- Go to the target repository homepage. Choose Settings > Policy Settings > MR Evaluation.
- If you select Use custom dimensions for MR evaluation, you can set MR evaluation in multiple dimensions. There are default MR evaluation names in several dimensions. You can also enter a dimension name and press Enter to save it. The name can contain a maximum of 200 characters. A maximum of 20 dimensions can be created. If Use custom dimensions for MR evaluation is not selected, the single-dimension MR evaluation will be used.
