Help Center/ CodeArts Repo/ User Guide/ Managing Member Permissions/ Configuring Repo-Level Permissions
Updated on 2025-09-23 GMT+08:00
Table 1 Constraints on configuring repository permissions
Item
Permission constraints
  • Only modifiable by project administrators, owners of parent repository groups and repositories, and users with the repo setting permission.
  • If you are the creator of an MR, you have the highest permission on it. If there is no other policy settings, you can edit, comment, review, approve, merge, close, re-open, or delete the MR, regardless of the permission matrix.
Function constraint
For public repositories, you have the code download permission and the comment permission of MR by default, which cannot be deleted or modified. Other permissions are the same as the default permissions of private repositories.
After confirming that you are an administrator, go to the CodeArts Repo homepage and click the name of the code repository to be set. On the displayed code repository details page, click Members on the navigation bar to add members to the code repository.
Complete the member configuration of the code repository. On the navigation bar, choose Settings. On the settings page that is displayed, choose Security Management >. Permissions. If Inherit from project is enabled, the permissions of members in the current role list will be the same as those of the project, and the current permission configuration will be overwritten.
Click on the right to synchronize the custom role of the project. By default, the custom role does not have the repository operation permission. After the synchronization, you can add the permission in Table 2 as required. A indicates that the role has the permission by default and cannot be removed. B indicates that the role has the permission by default and can be removed. C indicates that the role can be assigned with the permission. D indicates that the role cannot be assigned with the permission.
Table 2 Configuring permissions for repo roles
Role/Permission
Permission
Project Manager
Product Manager
Test Manager
Operation Manager
System Engineer
Committer
Developer
Tester
Participant
Viewer
Custom Role
Repository
fork
B
C
B
C
B
B
B
C
C
D
C
Delete
B
D
D
D
D
D
D
D
D
D
C
Set
B
D
D
D
D
D
D
D
D
D
C
Code
Commit
B
C
C
C
A
A
A
C
C
D
C
Download
B
C
C
C
A
A
A
C
C
D
C
Members
Add
B
D
D
D
D
D
D
D
D
D
C
Edit
B
D
D
D
D
D
D
D
D
D
C
Delete
B
D
D
D
D
D
D
D
D
D
C
Branch
Create
B
C
C
C
B
B
B
C
C
D
C
Delete
B
C
C
C
B
B
B
C
C
D
C
Tag
Create
B
C
C
C
B
B
B
C
C
D
C
Delete
B
C
C
C
C
C
C
C
C
D
C
MR
Create
B
C
C
C
B
B
B
C
C
D
C
Edit
B
D
D
D
C
B
C
D
D
D
C
Comment
B
C
C
C
B
B
B
C
C
C
C
Review
B
D
D
D
B
B
B
D
D
C
C
Approve
B
D
D
D
C
B
C
D
D
D
C
Merge
B
D
D
D
C
B
C
D
D
D
C
Close
B
D
D
D
C
B
C
D
D
D
C
Re-open
B
D
D
D
C
B
C
D
D
D
C
