Updated on 2025-09-23 GMT+08:00
Configuring Protected Branch Rules
Table 1 Constraints on configuring protected branch rules
Item
Permission constraint
To configure protected branch rules for a repository, you need to have the necessary permissions. For details, see Configuring Repo-Level Permissions.
Function constraint
Only one protected branch rule can be created for a branch. Otherwise, the error message indicating that the operation failed and the protected branch xxx already exists is displayed.
Configuring a Protected Branch
Go to the repository details page and choose Settings > Policy Settings > Protected Branches.
If you select Inherit from project, the settings of the project are automatically inherited and cannot be modified. If you do not select this option, see 2.
Managing a Protected Branch
Click in the row where the protected branch resides to modify the protected branch rule.
Click in the row where the protected branch resides to delete the protected branch rule.
