Updated on 2025-07-25 GMT+08:00
Configuring Webhook Settings
Overview
Developers can configure URLs of third-party systems on the Webhook page and subscribe to events such as branch push and tag push of CodeArts Repo based on project requirements. When a subscribed event occurs, you can use a webhook to send a POST request to the URL of a third-party system to trigger corresponding operations (in the third-party system), such as popping up a notification window, building or updating images, or performing deployment.
Before configuring a merge request rule, check Constraints. If you have the configuration permission, configure the rule based on Configuring Webhook Settings. For details about the configuration example, see Related Document.
Table 1 Constraints
Item
Permission settings
Project manager or project administrator can set project-level webhooks. For details, see Configuring Project-Level Permissions.
Function constraint
A maximum of 20 webhooks can be created for a repository.
To configure webhooks, choose Settings > Service Integration > Webhooks on the repository details page. You can set parameters by referring to the following figure or table. For details about the configuration result, see Related Document.
Table 2 Parameters for creating a webhook
Example Value
Name
Custom name with up to 200 characters.
Webhook_Test
Optional. Used to describe the webhook with up to 200 characters.
Test
URL
The URL and its response cannot contain sensitive data or the sensitive data must be encrypted and decrypted for security. Provided by the third-party CI/CD system.
https://example.com
Token Type
Optional. Used for authentication of third-party services' webhook APIs. The authentication information should be placed in the HTTP request header as the key and used together with the token. Three options are available:
  • X-Repo-Token
  • X-Gitlab-Token
  • X-Auth-Token
You can also enter a custom token type.
You can configure a token when setting up a webhook. The token will be associated with the webhook URL and sent to you in the X-Repo-Token header.
X-Repo-Token
Token
Optional. After you set Token Type, this parameter is used as the value and is used together with the token type.
Enter a custom value, with max. 2,000 characters. Used for third-party CI/CD system authentication. The authentication information is stored in the HTTP request header.
Token_Test
Trigger Events
You can subscribe to the following events:
  • Code push After this option is selected, you need to enter the Regular Expression for Branch Filtering with up to 500 characters. .* indicates that all branches are matched. If the branch name matches the configured regular expression and the code is updated (code updates in sub-modules; online or offline code push in Git client), the event will be triggered.
  • Merge requests After this option is selected, updating the MR code, closing MRs, re-opening MRs, updating MR title or description, updating the merger and the work item, deleting source branches, or updating the Squash merge will trigger this event.
  • Tag push After this option is selected, both creating and deleting a tag will trigger this event.
  • Comments After this option is selected, this event will be triggered when a review is added to a code file, a file change in a code commit, or an MR, or when a comment is added to a repository's commit details or MR details.
  • Select Code Push and set Regular Expression for Branch Filtering to Branch_*. This indicates that the push of all branches starting with Branch_ will trigger this event.
  • Select Merge requests.
  • Select Tag push.
Related Document
  • After the configuration is complete, the webhook of push event is triggered. As shown in the following figure, 200 is returned. If the token value in the code example is different from that configured in the table, the authentication fails and the error code 401 is returned.
