Feature Branch Workflow
This function allows teams to independently develop new functions or fix bugs without affecting the master branch (usually master or main). The core of this workflow is to use branches to manage different development phases, improving team collaboration efficiency and code quality.
Advantages
- Parallel development: Team members can independently develop new functions or fix problems without affecting the master branch.
- Code isolation: Each branch is independent. That is, the change of a branch does not affect other branches, reducing the risk of code conflicts.
- Fast iteration: By creating and merging branches, teams can quickly iterate new functions or fixes, accelerating software development.
- Easy management: Branches can be created and merged using the Git command line tool or GUI, making versioning more intuitive and convenient.
- Code review: Code review before merging branches helps ensure code quality and knowledge sharing among team members.
- Rollback and cancellation: Code can be quickly restored to the previous state when a problem occurs during development.
Disadvantages
- Complex merge: When multiple function branches need to be merged back to the master branch, complex merge conflicts may occur. In this case, you need to resolve the merge conflicts.
- Resource consumption: Maintaining multiple function branches may consume more computing resources and storage space.
- Branch management: Effective branch management policies are required to prevent too many branches or disordered relationships between branches.
Working on a Function Branch Workflow
- Create a code repository. Currently, CodeArts Repo supports creating a custom repository, creating a repository by using a template, forking an existing repository, and Migrating Code and Syncing a Repository.
- Create a local branch and compile code or create a branch online and compile code.
- Commit the modified code file to the cache. Currently, Repo supports code commit with Git Bash and Eclipse.
- Create a merge request.
- Resolve review comments.
- Committers merge the MR.
