Managing CodeArts Departments
If there are multiple projects that need the same group of members in your account, you can add these members to a department and associate the department with the projects.
- A department can have a maximum of 5 levels.
- A department can contain a maximum of 1,000 members.
- A project can be associated with a maximum of 5 departments.
- A department can be associated with a maximum of 100 projects.
| Step | Description |
| Create a department. Ensure that you have the General > Organization Structure > Create permission. | |
| A user who has related permissions under General > Organization Structure can manage the department. |
Step 1: Create a Department
- Go to the CodeArts homepage.
- Log in to the CodeArts console, click
, and select a region where you have enabled CodeArts. - Click Go to Workspace.
If your account uses the old billing mode (see Old Billing Modes), click Access Service.
- Click the username
on the top navigation bar and choose All Account Settings. - Choose General > Members.
- Click the Organization Structure tab and create a department of the desired type.
- Top-level department: Click Create.
- Sub-department: Locate the target department and click
Figure 1 Creating a department
- In the displayed dialog box, enter a department name, select users, and click Next.
The name can contain a maximum of 200 characters. Letters, digits, spaces, and the following special characters are supported: ()[]-_~.&
- Assign a role to each user and click OK.
The new department is displayed. Click the department name to view its members.
Step 2: Manage a Department
| Operation | Step |
| Editing a department |
| Deleting a department | WARNING:
| Managing department members |
