Updated on 2026-09-17 GMT+08:00
Multimodal Input
CodeArts Agent supports uploading images and other attachments to integrate them into the chat context. You can directly upload or drag and drop error screenshots, code blocks, or technical documentation into the input box. This eliminates the need for lengthy text descriptions, allowing you to clearly reproduce the problem scenario and achieve precise, efficient communication of your requirements.
Table 1 Constraints
Category
Agent mode
  • Uploading images from a local directory: You can upload images in PNG, JPG, JPEG, and WebP formats. Individual image sizes must not exceed 10 MB, and the total size cannot exceed 20 MB.
  • Uploading other attachments from a local directory: You can upload 1 to 20 items at a time with no file size limits. Supported formats: XLS, XLSX, CSV, DOC, DOCX, PPT, PPTX, PDF, MD, MDX, MDC, TXT, and SVG.
  • Dragging and dropping images or other files from the project directory
    Find the target image or file in the file tree under the explorer on CodeArts Agent IDE, and drag it into the input box to upload it.
Intelligent Q&A mode
Only local images can be uploaded. Other local attachments cannot be uploaded.
  • Uploading images from a local directory: You can upload 1 to 5 images at a time. Each image or the total size of all images must not exceed 4 MB. Supported formats: PNG, JPG, and JPEG.
OS
The voice input function is supported only on the following OSs:
  • Windows: Windows 11 (x64) is recommended. For Windows 10 (x64), the version must be 2019 or later, and upgrading to the latest stable version is recommended.
  • macOS: macOS 11 or later, compatible with ARM64 (Apple Silicon).
Uploading Images in a Chat
Example: uploading a code block screenshot to the agent.
  1. Switch to the agent mode.
    1. Log in to CodeArts Agent IDE as instructed in Quick Start.
    2. At the bottom of the input box on the chat panel, choose Built-in > Agent to switch to the agent mode. The selected model is displayed on the right. You can select a model as required from the drop-down list.
      If the chat panel of CodeArts Agent is not displayed, click (Expand AI Side Bar) in the upper right corner of the top menu bar to open it.
  2. Upload an image.
    • Images from a local directory
      Click in the input box, select Upload Attachments, and upload a local image. You can also drag and drop a local image into the input box to upload it.
    • Images from the clipboard
      Paste into the input box to upload an image from your clipboard.
    • Images from the project directory
      Find the target image in the file tree under the explorer on CodeArts Agent IDE, and drag it into the input box to upload it.
  3. View the image recognition results.
    Figure 1 Image recognition results
Uploading Other Attachments in a Chat
Example: uploading a PDF file to the agent.
  2. Click in the input box, select Upload Attachments, and upload a local attachment.
  3. Enter a prompt and click . The agent will then create and execute a task based on the prompt.
Using Voice Input
Enable voice input when typing is inconvenient, when you need quick verbal communication, or when structuring text instructions is difficult. This function supports up to 10 minutes of continuous recording each time, eliminating lengthy text descriptions and helping you achieve precise and efficient communication of your needs.
When using this function for the first time, ensure that microphone access is enabled. If it is disabled, configure it in your system settings. (The exact interface may vary depending on your OS.)
  • Windows: Go to Start > Settings > Privacy & security and allow microphone access.
  • macOS: Go to System Settings > Privacy & Security and allow microphone access.
  2. Set the language for voice input.
    1. Click in the upper right corner to open the global setting page.
    2. In the navigation pane of the Settings tab, click Chats.
    3. Choose Chat Settings > Voice Settings and specify the language for voice input.
  3. At the bottom of the input box on the chat panel, click and start speaking. The AI will automatically convert your voice input into text and enter it in the input box.
    The duration of a single voice input cannot exceed 10 minutes.
  4. Once you finish voice input, click and then . The agent will automatically create a task based on your prompt.
    If there are errors in the voice recognition result, you can edit the text manually before sending.
