Updated on 2026-08-24 GMT+08:00
CodeArts Agent allows you to quickly report problems and suggestions encountered during use, helping the product team continuously optimize the product. It also effectively connects developers to promote communication and cooperation.
Submitting Feedback in the IDE (Recommended)
If you use CodeArts Agent IDE, you can submit feedback in the IDE directly.
  1. Log in to CodeArts Agent IDE as instructed in Quick Start.
  2. In the upper right corner, click and choose Feedback.
    You can also click in the upper right corner of CodeArts Agent IDE to open the settings page. Then on the About CodeArts Agent tab, click Feedback.
  3. Select the feedback type.
    • Submitting bugs: Feedback on issues discovered in the software, including interface errors, function exceptions, and operation freezing.
    • My suggestions: This is used to collect your innovative ideas or suggestions on product functions. Describe your suggestions as detailed as possible. We will take your suggestions and consider them in the development plan later.
  4. Enter your feedback by referring to Table 1.
    Table 1 Feedback
    Explain the issue or provide suggestions clearly. Keep it no more than 1,000 characters. For feedback related to chats on CodeArts Agent, copy and paste the relevant chat details here.
    Screenshot
    In addition to describing the issue in text, you can also upload a screenshot of the issue.
    You can upload up to 10 images at a time. The image format must be JPG, PNG, or GIF, and the total size cannot exceed 5 MB.
    Contact
    Provide your contact information to help us better locate issues.
    Auxiliary information
    Choose whether to provide plug-in information and application logs as required. The information is used only to help locate, reproduce, and resolve issues.
    • Plug-in information: names, versions, and memory usage of all enabled plug-ins.
    • Application logs: logs generated when CodeArts Agent is used.
  5. Click Submit. After the feedback is submitted successfully, a success message is displayed.
Submitting a Service Ticket
If you encounter any issues when using CodeArts Agent, you can also submit a service ticket to Huawei Cloud for customer service support.
