Help Center/ CodeArts Agent/ User Guide (IDE)/ Settings/ Process Resources Explorer
Updated on 2026-09-17 GMT+08:00
The process resources explorer monitors CodeArts Agent IDE's resource use in real time, helping you adjust processes as needed and maintain its stability and performance.
Opening the Process Resources Explorer
In the lower left corner of CodeArts Agent IDE, click (normal state) to open the resources explorer.
If the process resources explorer icon is displayed in another state, the meanings are as follows:
  • : Network latency is too high.
  • : Network connection is interrupted.
  • : Memory/CPU utilization is too high.
Figure 1 Opening the process resources explorer
Viewing Resource Usage
The process resources explorer can:
  • Monitor the CPU usage of the current system.
  • Monitor the memory usage of the current system.
  • Display the disk usage of the current system.
  • Display the read/write speed, usage, and I/O status in real time when you hover the mouse over the disk information icon, giving you quick insights into storage performance.
  • Monitor network connectivity, proxy configurations, and latency in real time. This allows you to quickly determine whether an abnormal response stems from a network fault, helping pinpoint the exact root cause of the issue.
