Quick Start
This section describes how to install CodeArts Agent IDE to quickly start intelligent coding.
Preparations
- Before coding with CodeArts Agent IDE, create a Huawei Cloud account and purchase a package.
- Visit the Huawei Cloud official website, and click Sign Up in the upper right corner.
- Sign up for a Huawei Cloud account.
- Subscribe to a CodeArts Agent package.
CodeArts Agent is available in three editions: free, basic, and professional. Select one based on your service requirements. For details about how to subscribe to a package, see Subscriptions.
- Install a browser, such as Chrome.
During IDE login, the system redirects you to a browser for account verification. To ensure a smooth process, deploy and configure an available browser in the Linux environment in advance.
Installing CodeArts Agent IDE
- Download the CodeArts Agent IDE installation package from the official website of CodeArts Agent.
- Double-click the package and complete the installation as prompted.
If you need to install the package applicable to the Linux (ARM64) architecture and the double-click installation fails, you can install it using the command line.
- Go to the official website of CodeArts Agent, obtain the Linux installation package, and upload it to your Linux terminal.
- Switch to the directory containing the installation package, and run the following command to install it:
sudo dpkg -i codearts-agent-linux-arm64-***-***.deb
When running this command, replace the example package name codearts-agent-linux-arm64-***-***.deb with the name of the installation package you actually obtained.
- Log in to CodeArts Agent IDE and start intelligent coding.
- (Optional) Log out of CodeArts Agent IDE.
To log out, click
in the upper right corner of CodeArts Agent IDE and choose Log Out.
Creating or Opening a Project
After installing CodeArts Agent IDE, you can start your development in any of the following ways:
Related Operations
- If Microsoft Store briefly flashes and does not respond when you double-click the .exe installer of the IDE, see What Do I Do If the .exe Installer Crashes After Being Double-Clicked in Windows?
- To uninstall CodeArts Agent IDE on Linux, see How Do I Install CodeArts Agent IDE on Linux Using Commands?
- For how to convert Windows line breaks (CRLF) to Linux-recognizable line breaks (LF), refer to How Do I Handle Windows CRLF Line Endings That Cause Execution Errors in Linux?
- CodeArts Agent displays the message "Restricted mode. Functions not available." Handle it by referring to How Do I Handle the Error "Restricted mode. Functions not available."?
