Help Center/
      Cloud Operations Center/
        User Guide/
        Resilience Center/
        Drill Templates/
      Viewing a Drill Template
        Updated on 2025-07-29 GMT+08:00
There are several frequently-used drill templates in the template list. You can filter them by drill name and description (case insensitive).
Viewing Drill Template Details
- Log in to COC.
 - In the navigation pane, choose Resilience Center > Drill Templates.
 - Click the target template card in the list. The template details page is displayed.
For details about the template information, see Drill Template Description.
