Overview
A drill template is designed for building, managing, and optimizing fault drills. It contributes a systematic process to improve the efficiency of drill lifecycle management to some extend. This drill template helps you quickly create a specific fault drill, covering the entire process including creation, maintenance, and update. You will conduct a real, effective, and reusable drill on your system.
Core Features
- Out-of-the-box standardized design
- There are multiple preset templates designed for typical scenarios (such as cross-AZ DR and data storage exception scenarios). You can use the templates to create drill tasks.
- You can customize scenarios based on the existing ones to meet your specific service requirements like special service process and customized risk situations.
- Scenario library for actual requirements
- Built-in industry-typical scenario library: covers common service scenarios (such as high system resource usage and automatic traffic switchover) and contingency plan scenarios (such as data storage exceptions and environment overload in the microservice architecture).
- Scenario-based tag management: improves co-work efficiency using templates filtered by template name and description.
Core Advantages
Item |
Description |
High efficiency |
Accessible for all |
Scenario validity |
Flexibility and scalability |
Knowledge accumulation |
Typical Scenarios
- Enterprise emergency drills: Quickly enable contingency plans when you need to respond to cyber security attacks, handle production incidents, and more.
- Compliance drills: Customize scenarios (such as data privacy protection) based on regulatory requirements to ensure that drills comply with industry specifications.
- Routine drills: Perform chaos drills regularly based on different template scenarios to identify and avoid live network problems.
