On this page
Batch Restarting RDS Instances
Updated on 2024-11-20 GMT+08:00
Restart RDS database instances in batches on COC.
Precautions
Instances that have been stopped cannot be selected.
  1. Log in to COC.
  2. In the navigation pane on the left, choose Resource O&M > Resource Batch Operations, and click Restart RDS in RDS Operations.
  3. On the Restart RDS page, click Add.
    Figure 1 Selecting instances
  4. Select Batch Policy.
    • Automatic: The selected hosts are automatically divided into multiple batches based on the preset rule.
    • Manual: You can manually create multiple batches and add instances to each batch as required.
    • No batch: All target instances are in the same batch.
  5. Set Suspension Policy.
    • You can set the execution success rate. When the number of failed hosts reaches the pre-set suspension threshold figure, the service ticket status becomes abnormal and the service ticket stops being executed.
    • The value range is from 0 to 100 and can be set to one decimal place.
  6. Click Submit.
    Figure 2 Restarting RDS instances
  7. View the execution result.
    Figure 3 Execution result
  8. If the execution result is abnormal, you can click the Retry button in the Operation column or the Batch Retry button above the list to re-execute the failed one or more tasks. You can also click the Cancel button in the Operation column or Batch Cancel button above the list to skip one or more abnormal tasks.
    Figure 4 Canceling or retrying batch tasks
