Viewing Resource Types Supported by COC
A resource is an object that is contained in a service. Table 1 lists the resources supported by COC. You can specify resource paths to select specific resources when creating a custom policy.
| Resource Type | Resource Name | Path |
| instance | ECS | Format: ecs:*:*:instance:ECS instance ID [Description] For ECS resources, IAM automatically generates the prefix ecs:*:*:instance: of the resource path. You can use ECS ID to specify a resource path. Wildcards (*) are supported. The following is an example: ecs:*:*:instance:* indicates any ECS ID. |
| BMSs | Format: bms:*:*:instance:BMS ID [Description] For BMS resources, IAM automatically generates the prefix bms:*:*:instance: of the resource path. You can use a BMS instance ID to specify the resource path. The wildcard (*) is supported. The following is an example: bms:*:*:instance:* indicates any BMS ID. | |
| GaussDB instance | Format: GaussDB:*:*:instance:GaussDB instance ID [Description] For GaussDB instance resources, IAM automatically generates the prefix (gaussdb:*:*:instance:) of the resource path. You can use a GaussDB instance ID to specify a resource path. The wildcard (*) is supported. The following is an example: gaussdb:*:*:instance:* indicates any GaussDB instance ID. | |
| RDS instance | Format: rds:*:*:instance:RDS instance ID [Description] For RDS instance resources, IAM automatically generates the prefix (rds:*:*:instance:) of the resource path. You can use an RDS DB instance ID to specify the resource path. The wildcard (*) is supported. The following is an example: rds:*:*:instance:* indicates any RDS DB instance ID. | |
| document | Document | Format: coc:*:*:document:document name [Description] For document resources, IAM automatically generates the resource path prefix coc:*:*:document:. You can use a document name to specify the resource path. The wildcard (*) is supported. The following is an example: coc:*:*:document:* indicates any document. |
| application | Application | Format: coc:*:*:application:application code [Description] For application resources, IAM automatically generates the resource path prefix coc:*:*:application:. You can use an application code to specify the resource path. The wildcard (*) is supported. The following is an example: coc:*:*:application:* indicates any application. |
| resourceView | Resource views | Format: coc:*:*:resourceView:application code [Description] For resource view resources, IAM automatically generates the resource path prefix coc:*:*:resourceView:. You can use a resource view ID to specify the resource path. The wildcard (*) is supported. The following is an example: coc:*:*:resourceView:* indicates any resource view. |
| schedule | Scheduled O&M | Format: coc:*:*:schedule:scheduled task ID [Description] For scheduled O&M resources, IAM automatically generates the resource path prefix coc:*:*:schedule. You can use a scheduled task ID to specify the resource path. The wildcard (*) is supported. The following is an example: coc:*:*:schedule:* indicates any scheduled O&M. |
| job | Task | Format: coc:*:*:job:task ID [Description] For task resources, IAM automatically generates the resource path prefix coc:*:*:job:. You can use a task ID to specify the resource path. The wildcard (*) is supported. The following is an example: coc:*:*:job:* indicates any task. |
| faultMode | Failure modes | Format: coc:*:*:faultMode:failure mode ID [Description] For failure mode resources, IAM automatically generates the resource path prefix coc:*:*:faultMode:. You can use a failure mode ID to specify the resource path. The wildcard (*) is supported. The following is an example: coc:*:*:faultMode:* indicates any failure mode. |
| contingencyPlan | Contingency plans | Format: coc:*:*:contingencyPlan:contingency plan ID [Description] For contingency plan resources, IAM automatically generates the resource path prefix coc:*:*:contingencyPlan:. You can use a contingency plan ID to specify the resource path. The wildcard (*) is supported. The following is an example: coc:*:*:contingencyPlan:* indicates any contingency plan. |
| attackTask | Attack task | Format: coc:*:*:attackTask:attack task name [Description] For attack task resources, IAM automatically generates the resource path prefix coc:*:*:attackTask:. You can use an attack task name to specify the resource path. The wildcard (*) is supported. The following is an example: coc:*:*:attackTask:* indicates any attack task. |
| attackRecord | Attack record | Format: coc:*:*:attackRecord:attack record ID [Description] For attack record resources, IAM automatically generates the resource path prefix coc:*:*:attackRecord:. You can use an attack record ID to specify the resource path. The wildcard (*) is supported. The following is an example: coc:*:*:attackRecord:* indicates any attack record. |
| drillTask | Drill task | Format: coc:*:*:drillTask:drill task ID [Description] For drill task resources, IAM automatically generates the resource path prefix coc:*:*:drillTask:. You can use a drill task ID to specify the resource path. The wildcard (*) is supported. The following is an example: coc:*:*:drillTask:* indicates any drill task. |
| attackTargetRecord | Attack target record of an attack task | Format: coc:*:*:attackTargetRecord: attack target record ID of an attack task [Description] For the attack target record resource of an attack task, IAM automatically generates the resource path prefix coc:*:*:attackTargetRecord:. You can use an attack target record ID of an attack task to specify a resource path. The wildcard (*) is supported. The following is an example: coc:*:*:attackTargetRecord:* indicates the attack target record of any attack task. |
| drillRecord | Drill record | Format: coc:*:*:drillRecord:drill record ID [Description] For drill record resources, IAM automatically generates the resource path prefix coc:*:*:drillRecord:. You can use a drill record ID to specify a resource path. The wildcard (*) is supported. The following is an example: coc:*:*:drillRecord:* indicates any drill record. |
| drillPlan | Drill plans | Format: coc:*:*:drillPlan: drill plan ID [Description] For drill plan resources, IAM automatically generates the resource path prefix coc:*:*:drillPlan:. You can use a drill plan ID to specify a resource path. The wildcard (*) is supported. The following is an example: coc:*:*:drillPlan:* indicates any drill plan. |
| slaTemplate | SLA templates | Format: coc:*:*:slaTemplate:SLA template ID [Description] For SLA template resources, IAM automatically generates the resource path prefix coc:*:*:slaTemplate:. You can use an SLA template ID to specify the resource path. The wildcard (*) is supported. The following is an example: In the preceding command, coc:*:*:slaTemplate:* indicates any SLA template. |
| parameter | Configuration item | Format: coc:*:*:parameter:configuration item name. [Description] For configuration item resources, IAM automatically generates the resource path prefix coc:*:*:parameter:. You can use a configuration item name to specify the resource path. The wildcard (*) is supported. The following is an example: coc:*:*:parameter:* indicates any configuration item. |
| accountBaseline | Account baselines | Format: coc:*:*:accountBaseline:account baseline ID [Description] For account baseline resources, IAM automatically generates the resource path prefix coc:*:*:accountBaseline:. You can use an account baseline ID to specify a resource path. The wildcard (*) is supported. The following is an example: coc:*:*:accountBaseline:* indicates any account baseline. |
| provisionedProduct | Product instances | Format: coc:*:*:provisionedProduct:product instance ID [Description] For product instance resources, IAM automatically generates the resource path prefix coc:*:*:provisionedProduct:. You can use a product instance ID to specify the resource path. The wildcard (*) is supported. The following is an example: coc:*:*:provisionedProduct:* indicates any product instance. |
| product | Product | Format: coc:*:*:product:product ID [Description] For product resources, IAM automatically generates the prefix coc:*:*:product: of the resource path. You can use a product ID to specify the resource path. The wildcard (*) is supported. The following is an example: coc:*:*:product:* indicates any product. |
| portfolio | Product portfolio | Format: coc:*:*:portfolio:product portfolio ID [Description] For product portfolio resources, IAM automatically generates the resource path prefix coc:*:*:portfolio:. You can use a product portfolio ID to specify the resource path. The wildcard (*) is supported. The following is an example: coc:*:*:portfolio:* indicates any product combination. |
| sloDiagram | SLO architecture design diagram | Format: coc:*:*:sloDiagram:SLO architecture design diagram ID [Description] For SLO architecture design diagram resources, IAM automatically generates the resource path prefix coc:*:*:sloDiagram:. You can use an SLO architecture design diagram ID to specify the resource path. The wildcard (*) is supported. The following is an example: coc:*:*:sloDiagram:* indicates any SLO architecture design diagram. |
| template | Template | Format: coc:*:*:template:template ID [Description] For template resources, IAM automatically generates the resource path prefix coc:*:*:template:. You can use a template ID to specify the resource path. The wildcard (*) is supported. The following is an example: coc:*:*:template:* indicates any template. |
| templateInstance | Template instance | Format: coc:*:*:templateInstance:template instance ID [Description] For template instance resources, IAM automatically generates the prefix coc:*:*:templateInstance: of the resource path. You can use a template instance ID to specify the resource path. The wildcard (*) is supported. The following is an example: coc:*:*:templateInstance:* indicates any template instance. |
| vm | VMs | Format: coc:*:*:vm: VM ID [Description] For VM resources, IAM automatically generates the resource path prefix coc:*:*:vm:. You can use a VM ID to specify a resource path. The wildcard (*) is supported. The following is an example: coc:*:*:vm:* indicates any VM. |
| ciRelationshipBaseline | Resource relationship models | Format: coc:*:*:ciRelationshipBaseline: resource relationship model ID [Description] For resource relationship model resources, IAM automatically generates the resource path prefix coc:*:*:ciRelationshipBaseline:. You can use a resource relationship model ID to specify the resource path. The wildcard (*) is supported. The following is an example: coc:*:*:ciRelationshipBaseline* indicates any resource relationship model. |
