Help Center/ CloudTable Service/ User Guide/ Using Doris/ Common SQL Commands of Doris/ Creating a Table
Updated on 2025-07-24 GMT+08:00
Creating a Table
This section describes the basic syntax and usage of the SQL statements for creating a table in a Doris cluster.
Basic Syntax
CREATE TABLE [IF NOT EXISTS] [database.]table ( column_definition_list, [index_definition_list] ) [engine_type] [keys_type] [table_comment] [partition_info] distribution_desc [rollup_list] [properties] [extra_properties]
Usage Example
- Create a common table named table1.
CREATE TABLE example_db.table1 ( k1 TINYINT, k2 DECIMAL(10, 2) DEFAULT "10.5", k3 CHAR(10) COMMENT "string column", k4 INT NOT NULL DEFAULT "1" COMMENT "int column" ) COMMENT "table comment" DISTRIBUTED BY HASH(k1) BUCKETS 32;
- Create a partitioned table named table2. Use the event_day column to partition the table into p201706, p201707, and p201708. The values are as follows:
- p201706: The value range is [Minimum value, 2017-07-01).
- p201707: The value range is [2017-07-01, 2017-08-01).
- p201708: The value range is [2017-08-01, 2017-09-01).
Each partition is hashed into 10 buckets based on siteid. The command for creating a table is as follows:
CREATE TABLE table2 ( event_day DATE, siteid INT DEFAULT '10', citycode SMALLINT, username VARCHAR(32) DEFAULT '', pv BIGINT SUM DEFAULT '0' ) AGGREGATE KEY(event_day, siteid, citycode, username) PARTITION BY RANGE(event_day) ( PARTITION p201706 VALUES LESS THAN ('2017-07-01'), PARTITION p201707 VALUES LESS THAN ('2017-08-01'), PARTITION p201708 VALUES LESS THAN ('2017-09-01') ) DISTRIBUTED BY HASH(siteid) BUCKETS 10 PROPERTIES("replication_num" = "3");
- You must specify at least three replicas when creating a table to ensure high availability.
- For a non-node cluster, you do not need to specify replicas.
- You can add a rollup to a table to improve query performance.
- By default, the Null property of a column in a table is true, which affects the query performance.
- The bucket column must be specified for a Doris table.
- View the table content.
- View tables in the current database.
SHOW TABLES;
+----------------------+ | Tables_in_example_db | +----------------------+ | table1 | | table2 | +----------------------+ 2 rows in set (0.01 sec)
- View the structure of table1.
DESC table1;
+----------+-------------+------+-------+---------+-------+ | Field | Type | Null | Key | Default | Extra | +----------+-------------+------+-------+---------+-------+ | siteid | int(11) | Yes | true | 10 | | | citycode | smallint(6) | Yes | true | N/A | | | username | varchar(32) | Yes | true | | | | pv | bigint(20) | Yes | false | 0 | SUM | +----------+-------------+------+-------+---------+-------+ 4 rows in set (0.00 sec)
- View the structure of table2.
DESC table2;
+-----------+-------------+------+-------+---------+-------+ | Field | Type | Null | Key | Default | Extra | +-----------+-------------+------+-------+---------+-------+ | event_day | date | Yes | true | N/A | | | siteid | int(11) | Yes | true | 10 | | | citycode | smallint(6) | Yes | true | N/A | | | username | varchar(32) | Yes | true | | | | pv | bigint(20) | Yes | false | 0 | SUM | +-----------+-------------+------+-------+---------+-------+ 5 rows in set (0.00 sec)
Parent topic: Common SQL Commands of Doris
