Updated on 2025-12-29 GMT+08:00
Viewing Doris Cluster Logs with LTS
Cluster logs are collected and sent to Log Tank Service (LTS). You can check or dump the collected cluster logs on LTS.
Path for storing Doris cluster logs: /var/log/doris/
Doris log types:
  • fe.log
  • fe.warn.log
  • fe.audit.log
  • be.INFO
  • be.WARNING
Enabling LTS
  1. Log in to the CloudTable console.
  2. Select a region in the upper left corner.
  3. Click Clusters. The cluster list is displayed.
  4. In the cluster list, click a cluster name to go to the cluster details page. In the navigation pane on the left, click Logs. The Logs page is displayed.
  5. Click in the upper left corner of the page to enable LTS.
    • If this function is enabled for the first time, the Create Agency dialog box is displayed. Click OK to authorize the agency.
    • If LTS has been enabled and authorized to create an agency, no authorization is required when LTS is enabled again.
Checking Cluster Logs
  5. Select View Logs in the Operation column. The LTS console is displayed.
Disable Logging
  5. Toggle off the LTS switch.
  6. Click OK in the dialog box.
