Help Center/ CloudTable Service/ User Guide/ Using HBase/ HBase Cluster O&M/ Managing HBase Cluster Logs/ Viewing HBase Cluster Logs with LTS
Updated on 2026-01-29 GMT+08:00
Cluster logs are collected and sent to Log Tank Service (LTS). You can check or dump the collected cluster logs on LTS.
Currently, the following log types are supported:
Path for storing HBase cluster logs: /var/chroot/cloudtable/hbase/logs/
- hbase-Ruby-master-$hostname.log
- hbase-Ruby-regionserver-$hostname.log
- hbase-audit.log
Enabling LTS
- Log in to the CloudTable console.
- Select a region in the upper left corner.
- Click Clusters. The cluster list is displayed.
- In the cluster list, click a cluster name to go to the cluster details page. In the navigation pane on the left, click Logs. The Logs page is displayed.
- Click the toggle button in the upper left corner of the page to enable LTS.
- If this function is enabled for the first time, the Create Agency dialog box is displayed. Click OK to authorize the agency.
- If LTS has been enabled and authorized to create an agency, no authorization is required when LTS is enabled again.
Checking Cluster Logs
- Select View Logs in the Operation column. The LTS console is displayed.
Disable Logging
- Toggle off the LTS switch.
- Click OK in the dialog box.
Parent topic: Managing HBase Cluster Logs
