Help Center/CloudTable Service/User Guide/Using Doris/Doris Enterprise-class Enhancement/Configuring a Doris Tenant/Commands for Tenant Management
Updated on 2025-07-24 GMT+08:00
This section describes the basic syntax and usage of SQL statements for tenant management.
- Add a tenant.
create workload group if not exists test_group properties ( "cpu_share"="10", "memory_limit"="30%", "enable_memory_overcommit"="true", "max_concurrency" = "10", "max_queue_size" = "20", "queue_timeout" = "3000" ); - Modify a tenant.
alter workload group test_group properties ('cpu_share'='20','memory_limit'='4%','enable_memory_overcommit'='true','max_concurrency'='15','max_queue_size'='25','queue_timeout'='4000'); - Bind a user to a tenant: Bind a user to a workload group by setting user property. The default value is normal.
set property for doris_user 'default_workload_group' = 'test_group';
- Query the tenant to which the user belongs.
show property for user_name like 'default_workload_group';
- Grant permissions to the user bound to the tenant.
GRANT USAGE_PRIV ON WORKLOAD GROUP 'test_group' TO 'jack';
- Revoke the permissions of the old tenant.
revoke USAGE_PRIV ON WORKLOAD GROUP 'test_group' from 'jack';
- View tenants.
select * from information_schema.workload_groups;
- Delete a tenant.
mysql> DROP WORKLOAD GROUP if exists 'test_group'; Query OK, 0 rows affected (0.01 sec)
Parent topic:Configuring a Doris Tenant
