Expanding the Disk Capacity of an HBase Cluster
The vertical capacity expansion is performed by expanding disk capacity. Data is usually stored on the compute nodes, and disk expansion is required when the disk capacity of the compute nodes is insufficient.
- When the disk usage of all core nodes reaches 90%, the cluster is abnormal and read and write operations are unavailable.
- You can perform disk capacity expansion on a cluster when the cluster is in the In service state and no task is being performed (such as node scale-out and parameter modification).
- During disk capacity expansion, cluster services may jitter.
- If the core node storage specification uses common I/O, disk capacity expansion is not supported.
- Log in to the CloudTable console.
- Click Cluster Management.
- Select the cluster to be expanded and choose Operation > More > Disk Expansion.
You can also click Disk Expansion on the cluster details page to go to the page for expanding disk capacity.
- Click + to increase the disk capacity, confirm the fee and resource quota, and click OK.
Disk Expansion Status
Status | Description |
Disk expanding | Indicates that a cluster is being scaled out. |
In service (cluster status) | This status is shown in Cluster Status, indicating that the scale-out is complete and the cluster can provide services. |
Disk capacity expansion failed (task status) | This status is shown in Task Status, indicating that the cluster fails to be scaled out. |
