Help Center/
CloudTable Service/
User Guide/
Using Doris/
Connecting to a Doris Cluster/
Using the MySQL Client to Connect to a Doris Security Cluster
Updated on 2026-02-03 GMT+08:00
You can enable HTTPS to encrypt data transmission. This section describes how to enable HTTPS for a Doris cluster.
- Enabling security channel may cause cluster performance deterioration.
- The Doris cluster and the ECS must be in the same region, AZ, and VPC.
- The Doris cluster and the ECS must be in the same security group.
- The IP address of the local host has been added to the security group the ECS belongs to.
- Log in to the CloudTable console.
- Select a region in the upper left corner.
- Click Create Cluster in the upper right corner.
- Check whether Enable Https (which is toggled on by default) is toggled on after completing other configurations.
- Set the parameters and click Next.
- Confirm the cluster information and click Submit. After the cluster is created, go to its details page to view its security channel status.
- Click the name of the target security cluster to download the certificates on its details page.
- Specify the path for storing the certificates.
- Connect to the cluster. For details about how to download and install the client, see Installing the Client.
./mysql -uadmin -h Internal IP address of the cluster -PPort --ssl-ca={path}/certificate.crt --ssl-mode=VERIFY_CA -p Password- Cluster private IP address: private IP address of the cluster to be connected
- path: path for storing certificates.
- Port: MySQL server port 9030 on the FE node
- Password: password set during cluster creation
- {path}/certificate.crt: path for storing the downloaded certificate
Getting Started with Doris
- Create a database.
CREATE DATABASE demo;
- Create a data table.
- Use the database.
USE demo;
- Create a table.
CREATE TABLE IF NOT EXISTS demo.example_tbl ( `user_id` LARGEINT NOT NULL COMMENT "User ID", `date` DATE NOT NULL COMMENT "Data import date and time", `city` VARCHAR(20) COMMENT "City where the user locates", `age` SMALLINT COMMENT "User age", `sex` TINYINT COMMENT "User gender", `last_visit_date` DATETIME REPLACE DEFAULT "1970-01-01 00:00:00" COMMENT "Last visit date of the user", `cost` BIGINT SUM DEFAULT "0" COMMENT "Total consumption", `max_dwell_time` INT MAX DEFAULT "0" COMMENT "Maximum residence time", `min_dwell_time` INT MIN DEFAULT "99999" COMMENT "Minimum residence time", ) AGGREGATE KEY(`user_id`, `date`, `city`, `age`, `sex`) DISTRIBUTED BY HASH(`user_id`) BUCKETS 1 PROPERTIES ( "replication_allocation" = "tag.location.default:3" );
- Use the database.
- Insert data.
INSERT INTO demo.example_tbl (user_id,date,city,age,sex,last_visit_date,cost,max_dwell_time,min_dwell_time) VALUES('10000','2017-10-01','A','20','0','2017-10-01 07:00:00','35','10','2'),('10001','2017-10-01','A','30','1','2017-10-01 17:05:45','2','22','22'),('10002','2017-10-02','B','20','1','2017-10-02 12:59:12','200','5','5'),('10003','2017-10-02','C','32','0','2017-10-02 11:20:12','30','11','11'),('10004','2017-10-01','D','35','0','2017-10-01 10:00:15','100','3','3'),('10004','2017-10-03','D','35','0','2017-10-03 10:20:22','11','6','6'); - Query the data.
- Use Doris to perform quick data query and analysis.
mysql> SELECT * FROM demo.example_tbl; +---------+------------+------+------+------+---------------------+------+----------------+----------------+ | user_id | date | city | age | sex | last_visit_date | cost | max_dwell_time | min_dwell_time | +---------+------------+------+------+------+---------------------+------+----------------+----------------+ | 10000 | 2017-10-01 | A | 20 | 0 | 2017-10-01 07:00:00 | 35 | 10 | 2 | | 10001 | 2017-10-01 | A | 30 | 1 | 2017-10-01 17:05:45 | 2 | 22 | 22 | | 10002 | 2017-10-02 | B | 20 | 1 | 2017-10-02 12:59:12 | 200 | 5 | 5 | | 10003 | 2017-10-02 | C | 32 | 0 | 2017-10-02 11:20:12 | 30 | 11 | 11 | | 10004 | 2017-10-01 | D | 35 | 0 | 2017-10-01 10:00:15 | 100 | 3 | 3 | | 10004 | 2017-10-03 | D | 35 | 0 | 2017-10-03 10:20:22 | 11 | 6 | 6 | +---------+------------+------+------+------+---------------------+------+----------------+----------------+ 6 rows in set (0.02 sec)
- View information about a specified city.
mysql> SELECT * FROM demo.example_tbl where city='B'; +---------+------------+------+------+------+---------------------+------+----------------+----------------+ | user_id | date | city | age | sex | last_visit_date | cost | max_dwell_time | min_dwell_time | +---------+------------+------+------+------+---------------------+------+----------------+----------------+ | 10002 | 2017-10-02 | B | 20 | 1 | 2017-10-02 12:59:12 | 200 | 5 | 5 | +---------+------------+------+------+------+---------------------+------+----------------+----------------+ 1 row in set (0.10 sec)
- Delete data.
- Delete a specified row of data.
mysql> DELETE FROM demo.example_tbl WHERE user_id = 10003; Query OK, 0 rows affected (0.04 sec) {'label':'delete_77ed273a-a052-4d64-bac0-23916b698003', 'status':'VISIBLE', 'txnId':'39'} - Delete the table.
mysql> DROP TABLE demo.example_tbl; Query OK, 0 rows affected (0.01 sec)
Parent topic: Connecting to a Doris Cluster
