ClickHouse Cluster Supported Metrics
Monitoring is critical to ensure CloudTable reliability, availability, and performance. You can monitor the running status of CloudTable servers. This section describes the metrics that can be monitored by CES as well as their namespaces and dimensions.
Namespace
SYS.CloudTable
Monitoring metrics
Metric |
Name |
Description |
Minimum Unit |
Monitoring Period |
cpu_usage |
CPU Utilization Rate |
CPU utilization rate of each node. |
60 |
memory_usage |
Memory Usage |
Memory usage of each node. |
Byte |
60 |
memory_usage_ratio |
Memory Utilization Rate |
Memory utilization rate of each node. |
60 |
disk_usage |
Disk Usage |
Disk space used by each node. |
Byte |
60 |
disk_usage_ratio |
Disk Utilization Rate |
Disk utilization rate of each node. |
60 |
network_throughput_inbound_rate |
Inbound Throughput |
Inbound data volume over network of each node per second. |
Byte/s |
60 |
network_throughput_outgoing_rate |
Outbound Throughput |
Outbound data volume over network of each node per second. |
Byte/s |
60 |
clickhouse_process_survival |
ClickHouse Process Survival Status |
Heartbeat check of the ClickHouse process. |
60 |
number_of_mutations |
Mutations |
Number of running modification tasks on each node. |
Count |
60 |
number_of_run_merges |
Running Merges |
Number of running merge tasks. |
Count |
60 |
number_of_merges_thread |
Merge Threads |
Number of threads being merged. |
Count |
60 |
number_of_zookeeper_requests |
ZooKeeper Requests |
Number of ZooKeeper requests on the node at the current time. |
Count |
60 |
number_of_zk_session |
ZooKeeper Sessions |
Number of connected ZooKeeper sessions on the node at the current time. |
Count |
60 |
number_of_zookeeper_watches |
ZooKeeper Watches |
Number of connected ZooKeeper watches on the node at the current time. |
Count |
60 |
number_of_zookeeper_nodes |
ZooKeeper Nodes |
Number of temporary nodes created in ZooKeeper. |
Count |
60 |
number_of_parts |
Parts |
Number of parts. |
Count |
60 |
clickhouse_zookeeper_disconnection |
ZooKeeper Connection Status |
ZooKeeper connection status. |
60 |
number_of_threads_holding_read_locks |
Threads Holding the Read Lock |
Number of threads that hold read locks. |
Count |
60 |
number_of_threads_waiting_to_be_read |
Threads Waiting to Be Read |
Number of threads waiting to be read. |
Count |
60 |
number_of_threads_waiting_to_be_written |
Number of Threads Waiting to Be Written |
Number of threads waiting to be written. |
Count |
60 |
number_of_threads_holding_write_locks |
Threads Holding the Write Lock |
Number of threads that hold write locks. |
Count |
60 |
number_of_active_tasks_background_processing_pool |
Active Tasks in Background Processing Pool |
Number of active tasks in the background processing pool. |
Count |
60 |
maximum_number_of_active_blocks |
Max. Active Blocks |
Maximum number of active blocks of the ClickHouse instance. |
Count |
60 |
number_of_consistency_checkdata_blocks |
Data Blocks for Consistency Check |
Number of data blocks for consistency check on a ClickHouse instance. |
Count |
60 |
extracting_the_number_of_data_chunks_from_the_replica |
Data Blocks Being Extracted from a Replica |
Number of data blocks that are being extracted from a replica by a ClickHouse instance. |
Count |
60 |
number_of_data_chunks_being_sent_to_the_replica |
Data Blocks Being Sent to a Replica |
Number of data blocks on a ClickHouse instance that are being sent to a replica. |
Count |
60 |
number_of_readonly_replicas |
Read-Only Replicas |
Number of read-only replicas of a ClickHouse instance. |
Count |
60 |
number_of_inserted_into_all_tables |
Inserted Rows |
Number of rows inserted into all tables in a ClickHouse instance. |
Count |
60 |
number_of_open_read_files |
Opened Read Files |
Number of opened read files on a ClickHouse instance. |
Count |
60 |
number_of_open_write_files |
Opened Write Files |
Number of opened write files on a ClickHouse instance. |
Count |
60 |
total_file_opens |
Opened Files |
Number of opened files on a ClickHouse instance. |
Count |
60 |
number_of_read_file_descriptors |
Read File Descriptors |
Number of file descriptors that have been read. |
Count |
60 |
number_of_written_file_descriptors |
Write File Descriptors |
Number of file descriptors that have been written. |
Count |
60 |
instance_process_running_duration |
Instance Process Running Duration |
Running duration of the process on a ClickHouse instance. |
s |
60 |
number_of_threads_running_in_global_thread_pool |
Threads of Running Tasks in Global Thread Pool |
Number of threads of running tasks in the global thread pool of a ClickHouse instance. |
Count |
60 |
number_of_threads_in_global_thread_pool |
Threads in Global Thread Pool |
Number of threads in the global thread pool of a ClickHouse instance. |
Count |
60 |
number_of_threads_in_local_thread_pool |
Threads in Local Thread Pool |
Number of threads in the local thread pool of a ClickHouse instance. |
Count |
60 |
number_of_threads_waiting_locked |
Threads to Lock in Context |
Number of threads waiting to be locked in context on a ClickHouse instance. |
Count |
60 |
number_of_threads_running_in_local_thread_pool |
Threads of Running Tasks in Local Thread Pool |
Number of threads of running tasks in the local thread pool of a ClickHouse instance. |
Count |
60 |
number_of_tcp_connections |
TCP Connections |
Number of TCP connections. |
Count |
60 |
number_of_http_connections |
HTTP Connections |
Number of HTTP connections. |
Count |
60 |
number_of_databases |
Databases |
Number of databases on each node. |
Count |
60 |
number_of_tables |
Tables |
Number of local tables on each node. |
Count |
60 |
write_size_per_second |
Write Size per Second |
Amount of data written to each node per unit time. |
Byte |
60 |
number_of_running_queries |
Running Queries |
Number of running queries on each node. |
Count |
60 |
number_of_query_threads |
Query Threads |
Count |
60 |
number_of_distributed_ddls |
Distributed DDLs |
Number of distributed DDL statements. |
Count |
60 |
number_of_distributed_table_files |
Distributed Tables |
Number of tables to which data is to be inserted. |
Count |
60 |
number_of_concurrency |
Concurrency of Each ClickHouse Node |
Concurrency of each ClickHouse node. |
Count |
60 |
zookeeper_quota_percentage |
ZooKeeper Quantity Percentage |
Quota of the ZooKeeper nodes used by ClickHouse. |
60 |
zookeeper_process_is_alive |
ZooKeeper Process Survival Status |
ZooKeeper heartbeat check. 1 indicates that the ZooKeeper heartbeat is normal, and 0 indicates that it is abnormal. |
60 |
number_of_global_sessions |
Global Sessions |
Number of global sessions. |
Count |
60 |
number_of_rejected_connections |
Refused Connections |
Number of connections refused by Zookeeper. |
Count |
60 |
number_of_request_submission_queues |
Requests to Submit in a Queue |
Number of requests submitted in a queue. |
Count |
60 |
waiting_time_of_the_preprocessing_queue |
Wait Time of Request in Preprocessing Queue |
Time that a request in the preprocessing queue waits to be processed. |
s |
60 |
number_of_zk_watches |
ZooKeeper Watches |
Number of ZooKeeper watches at the current time. |
Count |
60 |
zk_heapmemory_usage |
Heap Memory Used |
Heap memory size used by ZooKeeper process. |
Byte |
60 |
zk_directmemory_usage |
Used Direct Memory |
Direct memory size used by ZooKeeper process. |
Byte |
60 |
zk_heapmemory_usage_ratio |
Heap Memory Usage |
Heap memory usage of the ZooKeeper service. |
60 |
zk_directmemory_usage_ratio |
Direct Memory Usage |
Direct memory usage of the ZooKeeper service. |
60 |
cluster_number_of_sent_packets |
ZooKeeper Sent Packets |
Number of packets sent by a ZooKeeper node. |
Count |
60 |
cluster_number_of_received_packets |
ZooKeeper Received Packets |
Number of packets received by a ZooKeeper node. |
Count |
60 |
cluster_preprocessing_time |
Preprocessing Duration |
Preprocessing time. |
s |
60 |
rows_written_per_second |
Rows Written per Second |
Number of rows written to each node per unit time. |
Count |
60 |
number_of_failed_queries |
Failed Queries |
Number of failed query statements. |
Count |
60 |
number_of_failed_insert_queries |
Failed Insert Queries |
Number of failed insert statements. |
Count |
60 |
number_of_failed_select_query_messages |
Failed Select Queries |
Number of failed select statements. |
Count |
60 |
number_of_delayed_inserts |
Delayed Inserts |
Number of delayed insertions on each node. |
Count |
60 |
number_of_rows |
Rows |
Number of mergetree engine fields on each node. |
Count |
60 |
disk_throughput_read_rate |
Disk Read Throughput |
Disk read throughput. |
Byte |
60 |
disk_throughput_write_rate |
Disk Write Throughput |
Disk write throughput. |
Byte |
60 |
cmdForUsedStorageRate |
Used Storage Rate |
Ratio of the used storage space to the total storage space in the cluster |
60 |
Dimension
Key |
Value |
cluster_id |
CloudTable cluster ID. |
instance_name |
Name of a CloudTable cluster node. |
