Help Center/CloudTable Service/User Guide/Using Doris/Configuring Doris User Permissions
Updated on 2026-01-29 GMT+08:00
In data processing scenarios, when multiple users access a Doris cluster for data analysis at the same time, data leakage or misoperations may occur due to the lack of an effective permission management mechanism, hindering service security and efficiency. Doris user permission management enables unified management of users, roles, and permissions on each node in the cluster. You can create roles, create users, and bind users to roles on the console to control user permissions. Operations of different users do not affect each other, improving service efficiency. In a multi-user environment, Doris user permission management uses fine-grained permission control to ensure that each user can access only authorized data and operations. This effectively prevents data leakage and misoperations, improving the security and efficiency of overall services.
  • The deletion operation is irreversible. Even if a role with the same name is added immediately after the deletion, the permission may be different from that of the deleted one. Ensure that the role is not in use before deleting it.
  • Before deleting a user, make sure that it is not needed anymore. The deletion operation is irreversible. Even if an account with the same name is added immediately after the deletion, the permission may be different from that of the deleted one.
  • The password of an existing account cannot be viewed. If you forget the password, you can reset the password.
  • The operation permissions of an account on the database can be viewed.
  • The username and role name are case sensitive.
  • A Doris cluster has been created and is running properly.
  • The MySQL client has been installed.
Step 1: Create a Doris Role
  1. Log in to the CloudTable console.
  2. Click Cluster Management. On the displayed cluster list page, select the target cluster and choose Cluster Name > Role Management. The role management page is displayed.
  3. Click Create Role. On the displayed page, configure parameters below.
    Table 1 Role permissions
    Rolename
    The role name must start with a letter and contain 1 to 64 characters.
    Global Permission
    Global permissions refer to the permissions on all databases and tables, including the SELECT, LOAD, ALTER, CREATE, and DROP permissions.
    Each Level Permission
    Database And Table refers to the databases and tables created in the cluster.
    • For databases, high-risk permissions and common permissions can be configured. For tables, only common permissions can be configured.
    • Permission types
      • High-risk permissions: CREATE TABLE and DROP TABLE
      • Common permissions: SELECT, LOAD, and ALTER
  4. Click OK. Return to the role management page and check whether the new role is displayed in the role list.
Step 2: Create a Doris User
  1. After a role is created, choose Account Management.
  2. Click Create Account. On the Create Account page, set the username and password.
    Table 2 Account parameters
    Username
    The username must start with a letter and contain 1 to 64 characters.
    Password
    Enter a password for the user.
    The password must meet the following requirements:
    • Contain 8 to 16 characters.
    • Contain at least four types of the following characters: uppercase letters, lowercase letters, digits, and special characters ($@!%*?&)
    • Cannot be the same as the username or the username spelled backwards.
    Confirm Password
    Enter the password again.
  3. Click OK. Return to the user management page and check whether the new user is displayed in the user list.
Step 3: Bind a Role to a Doris User and Access the Cluster
For example, role A has the permission to query, insert, modify, create, and delete data. After being bound to role A, the user has the permissions of role A.
  1. After a role and user are created, choose Account Management, locate the target account, click More, and select Assign Role in the Operation column.
  2. In the Assign Role dialog box, select a role. Click OK.
  3. Click Permission in the Operation column and check that the user has the role permissions.
  4. Connect to the cluster as the created user.
    For details about how to connect to a non-security cluster, see Using the MySQL Client to Connect to a Doris Normal Cluster.
    ./mysql -uadmin -pPassword -hInternal IP address of the cluster -P9030
    For details about how to connect to a security cluster, see Using the MySQL Client to Connect to a Doris Security Cluster.
    ./mysql -uadmin -hInternal IP address of the cluster -P9030 --ssl-ca={path}/certificate.crt --ssl-mode=VERIFY_CA -pPassword
  5. Execute the query, insert, change, create, and delete commands in the CLI.
    • If these commands can be executed, the role is bound successfully.
    • If these commands cannot be executed, check whether the role has been configured with permissions and whether it has been bound to the user. If the fault persists, contact technical support.
Managing User Permissions
  • Managing roles
    • Deleting a role: Click Delete in the Operation column. On the displayed page, enter DELETE in the text box or click Auto Enter, and click OK.
    • Modifying role permissions: Click Edit in the Operation column. On the displayed page, select permissions as needed and click OK.
    • Viewing role permissions: Click Permission in the Operation column. On the displayed page, view the role's permissions on databases and tables.
  • Managing users
    • Assigning a role: Choose More > Assign Role in the Operation column. In the displayed dialog box, select a role and click OK.
    • Viewing user permissions: Click Permission in the Operation column. On the displayed page, view the user's permissions on databases and tables.
    • Deleting a user: Click Delete in the Operation column. In the displayed dialog box, click Yes.
    • Changing the user password: Click More and select Update Password in the Operation column. On the displayed page, change the password and click OK.
Common Commands for User Permissions
  1. Creating a role
    CREATE Role role_name;
    role_name: name of the role to be created
  2. Assigning permissions to a role
    • Grant the permissions on a specified database table.
      GRANT LOAD_PRIV ON ctl1.db1.* TO ROLE 'my_role';
    • Grant the permission to use specified resources.
      GRANT USAGE_PRIV ON RESOURCE 'spark_resource' TO ROLE 'my_role';
  3. Deleting a role
    DROP ROLE role1;
  4. Creating a user
    • Use the CREATE USER command to create a Doris user (without a role).
      CREATE USER 'Jack' IDENTIFIED BY 'password';
      Table 3 Parameters
      Jack
      Username
      password
      Password of the created user
      You can run the command to specify an IP address.
      CREATE USER 'jack02' @'192.168.%'  identified by '123456'  DEFAULT ROLE 'default_role';
    • Use the CREATE USER command to create a Doris user (with the default role assigned).
      CREATE USER 'jeo' IDENTIFIED BY 'password' DEFAULT ROLE 'default_role';
  5. Changing a user password
    Use the ALTER USER command to change the password of a user.
    ALTER USER 'Jack' IDENTIFIED BY "password";
  6. Assigning a role to the user
    • Assign a role to the user.
      GRANT 'role1','role2' TO 'jack'@'%';
      Table 4 Parameters
      role
      Created role
      jack
      Created username
    • Revoke the role assigned to the user.
      REVOKE 'role1' FROM 'candy';
  7. Deleting a user
    DROP USER'Jack';
  8. Querying the permissions and roles of a user
    SHOW GRANTS;
