- Billing
- Getting Started
User Guide
HBase User Guide
HBase Cluster Management
- Overview
- Managing Clusters
- Preparing an ECS
- Using HBase
- HBase Cold and Hot Data Separation
- HBase Thrift Server
- HBase Security Channel Encryption
- HBase Batch Data Import
- HBase Monitoring Clusters
- Self-Healing from HBase Hotspotting
- Global Secondary Indexes
ClickHouse User Guide
ClickHouse Cluster Management
- Overview
- Managing ClickHouse Clusters
- Using ClickHouse
- Migrating ClickHouse Data
- ClickHouse User Management
- ClickHouse Role Management
- ClickHouse Slow Query Management
- Configuring Secure Channel Encryption for ClickHouse Clusters
- Application of ClickHouse Cold and Hot Data Separation
- ClickHouse Monitoring Clusters
- Permissions Management
- Audit Logs
- Cluster Log Management
HBase User Guide
Developer Guide
- HBase Application Development Guide
- ClickHouse Application Development Guide
General
- What Services Does a CloudTable Cluster Provide?
- Why Do I Choose CloudTable Service?
- How Do I Prepare for Creating a CloudTable HBase Cluster?
- What Should I Pay Attention to When Using CloudTable Service?
- What Compression Algorithms Are Supported by CloudTable HBase Clusters?
- Can I Stop CloudTable Service?
- Which Programming Languages Are Supported by HBase External APIs in CloudTable?
- How Do I Determine the Number of Faulty RegionServers?
- What Special Characters Does CloudTable HBase Support?
- What Can I Do If the Index Table Does Not Match the Data Table After CloudTable Data Is Deleted?
- What Should I Do If Concurrent Tasks Run Slowly When Python Accesses CloudTable Through Thrift?
- How do I view the TTL attribute of HBase shell?
- Why Are My Server Resources Released?
- How Do I Delete a Cluster?
- How Do I Stop Services and Release Resources?
Connection and Access
- How Do I Access a CloudTable Cluster?
- Can I Use SSH to Access Computing Nodes of CloudTable?
- Why Can't I Access HBase After the ZK Address Is Configured?
- Why Is the Error "Will not attempt to authenticate using SASL (unknown error)" Reported When Connecting to HBase?
- How Do I View the IP Address Corresponding to a Domain Name in a CloudTable Link?
- How Do I Access CloudTable from Other Cloud Services?
- Can I Configure the hbase-site.xml File?
- How Do I Query the Creation Time of a Table in CloudTable HBase?
Data Read/Write
- Is Raw Data Stored in CloudTable HBase?
- Why Can't I Write Data to HBase?
- What Is the Maximum Size of Data Written to the HBase Cluster?
- How Do I Check the Daily Incremental Data in HBase Tables?
- What Should I Do If an Error Is Reported When I Access the CloudTable HBase Cluster?
- How Do I Delete the Backup Table of the ZooKeeper Node in the ClickHouse Cluster?
- What Should I Do If a Database Missing Error Occurs When a Table Is Created in the ClickHouse Cluster?
- Billing FAQs
General
Querying Indexes
You can use the GSI tool to view the definition and status of indexes of a data table in batches.
Usage
Run the following command on the HBase client to view the definition and status of an index:
hbase org.apache.hadoop.hbase.hindex.global.mapreduce.GlobalTableIndexer -Dtablename.to.show='table'
The related parameters are described as follows:
tablename.to.show: indicates the name of the table where the index to be queried is.
Figure 1 shows the query result. The index column definition, covering column definition, TTL, pre-partition information, and index status are displayed.
