Help Center/ CloudTable Service/ User Guide/ Using ClickHouse/ Data Migration and Synchronization/ Importing and Exporting data
Updated on 2026-01-29 GMT+08:00
This section describes the basic syntax and usage of the SQL statements for importing and exporting file data using the ClickHouse client.
Importing and Exporting Data in CSV Format
- Import data in CSV format.
- Non-security cluster
cat csv_ssl | ./clickhouse client --host 192.168.x.x --port port --user admin --password password --database test010 --query="INSERT INTO test145 FORMAT CSV"
- Security cluster
cat csv_no_ssl | ./clickhouse client --host 192.168.x.x --port port --user admin --password password --config-file ./config.xml --database test010 --query="INSERT INTO test146 FORMAT CSV"
- host: indicates the host name or ClickHouse instance IP address.
- port: indicates the port number (available on the cluster details page).
- user: indicates the username created during cluster creation.
- database: indicates the database name.
- password: indicates the password specified during cluster creation.
- INSERT INTO: indicates the target data table.
- cat File path: indicates the user-defined path for storing the file.
- config-file ./config.xml: indicates the configuration file. For details, see Using a Client to Connect to a ClickHouse Security Cluster.
- Export data in CSV format.
./clickhouse client --host 192.168.x.x --port port --user admin --password Password --database test010 -m --query="select * from test139 FORMAT CSV" > ./csv_no_ssl
- Security cluster
./clickhouse client --host 192.168.x.x --port port --user admin --password password --config-file ./config.xml --database test010 -m --query="select * from test139 FORMAT CSV" > ./csv_no_ssl
- SELECT * FROM: indicates the target data table.
- ./csv_no_ssl: indicates the user-defined path for storing the file.
Importing and Exporting Data in Parquet Format
- Import data in Parquet format.
cat parquet_no_ssl.parquet | ./clickhouse client --host 192.168.x.x --port port --user admin --password password --database test010 --query="INSERT INTO test145 FORMAT Parquet"
- Security cluster
cat parquet_no_ssl.parquet | ./clickhouse client --host 192.168.x.x --port port --user admin --password password --config-file ./config.xml --database test010 --query="INSERT INTO test146 FORMAT Parquet"
- parquet_no_ssl.parquet: indicates the user-defined path for storing the file.
- Export data in Parquet format.
./clickhouse client --host 192.168.x.x --port port --user admin --password password --database test010 -m --query="select * from test139 FORMAT Parquet" > ./parquet_no_ssl.parquet
- Security cluster
./clickhouse client --host 192.168.x.x --port port --user admin --password password --config-file ./config.xml --database test010 -m --query="select * from test139 FORMAT Parquet" > ./parquet_ssl.parquet
- select * from: indicates the target data table.
- ./parquet_no_ssl.parquet: indicates the user-defined path for storing the file.
Importing and Exporting Data in ORC Format
- Import data in ORC format.
cat orc_no_ssl.orc | ./clickhouse client --host 192.168.x.x --port port --user admin --password password --database test010 --query="INSERT INTO test143 FORMAT ORC"
- Security cluster
cat orc_no_ssl.orc | ./clickhouse client --host 192.168.x.x --port port --user admin --password password --config-file ./config.xml --database test010 --query="INSERT INTO test144 FORMAT ORC"
- cat orc_no_ssl.orc: indicates the user-defined path for storing the file.
- Export data in ORC format.
- Security cluster
./clickhouse client --host 192.168.x.x --port port --user admin --password password --config-file ./config.xml --database test010 -m --query="select * from test139 FORMAT ORC" > ./orc_ssl.orc
./clickhouse client --host 192.168.x.x --port port --user admin --password password --database test010 -m --query="select * from test139 FORMAT ORC" > ./orc_no_ssl.orc
- Security cluster
- /opt/student.orc: indicates the user-defined path for storing the file.
Importing and Exporting Data in JSON Format
- Import data in JSON format.
cat ./jsonnossl.json | ./clickhouse client --host 192.168.x.x --port port --user admin --password password --database test010 --query="INSERT INTO test141 FORMAT JSON"
- Security cluster
cat ./jsonssl.json | ./clickhouse client --host 192.168.x.x --port port --user admin --password password --config-file ./config.xml --database test010 --query="INSERT INTO test142 FORMAT JSON"
- Export data in JSON format.
- Security cluster
./clickhouse client --host 192.168.x.x --port port --user admin --password password --database test010 -m --query="select * from test139 FORMAT JSON" > ./jsonnossl.json
./clickhouse client --host 192.168.x.x --port port --user admin --password password --config-file ./config.xml --database test010 -m --query="select * from test139 FORMAT JSON" > ./jsonssl.json
- Security cluster
- ./jsonssl.json: indicates the user-defined path for storing the file.
Parent topic: Data Migration and Synchronization
