Modifying Doris Parameters to Optimize Cluster Performance
In data analysis scenarios, you need to adjust the configuration parameters of Doris clusters as required to optimize performance. However, manually adjusting the configuration parameters is time-consuming and error-prone, which leads to fact that the cluster performance cannot reach the optimal state. You can adjust the configuration parameters of Doris clusters on the console for multiple times to optimize cluster performance, thereby improving data processing efficiency and system response speed.
- Modifying the static parameters of a cluster requires a cluster restart, which may interrupt services. To avoid impacting services, perform this operation during off-peak hours.
- You can modify parameters only when no task is running in the cluster.
- Do not modify cluster parameters when the cluster is being restarted.
- Log in to the CloudTable console.
- Select a region in the upper left corner.
- In the navigation pane on the left, choose Cluster Management.
- In the cluster list, locate the target cluster, click the cluster name, and go to the Parameter Configuration tab page.
- Select the target FE or BE node, select the parameter to be modified, and click
in the Value column. - Enter a new value in the text box and click
. The system displays a message "The parameter changed to xx successfully. Save the modified value." The new value is followed by a red asterisk (*).
To cancel the modification, click
.Figure 1 Modifying a parameter
- Click Save Changes in the upper left corner above the parameter list. A dialog box is displayed.
- Check the parameter settings and click OK.
Figure 2 Saving the modification
- Click
in the upper right corner. If Status of the parameter is Applied, the cluster does not need to be restarted. If Status is Unapplied, you need to manually restart the cluster for the modification to take effect. - Click Restart in the upper left corner of the Parameter Configuration page. Alternatively, return to the cluster list to restart the cluster.
Manually restart the cluster after the static parameters are modified. Dynamic parameters take effect after being modified. You do not need to restart the cluster.
- If the new parameter value is incorrect, click Quick Restore to cancel the modification.
- Click
- After modifying parameters, you can click the Change History tab to view the change history. The following table lists the parameters displayed on the Change History page.
Table 1 Parameters Parameter
Name
Name of the modified parameter
Old Value
Parameter value before modification
New Value
Parameter value after modification
Modified
Time when the parameter was modified
Doris Parameter Modification Status
Status |
Description |
Unmodified |
The parameter has not been modified. |
Unapplied |
The parameter has been modified but has not been applied. |
Applying |
This is a static parameter and you need to restart the cluster after saving the modification. |
Applied |
The modification of the parameter takes effect.
FE Node Parameters
BE Node Parameters
Parameter |
Static |
Description |
max_consumer_num_per_grou |
Yes |
clone_worker_count |
Yes |
