CREATE TABLE
This section describes how to create a table.
Creating a Local Table
CREATE TABLE [IF NOT EXISTS] [database_name.]table_name [ON CLUSTER default_cluster] ( name1 [type1] [DEFAULT|MATERIALIZED|ALIAS expr1], name2[type2] [DEFAULT|MATERIALIZED|ALIAS expr2], ... ) ENGINE = engine_name() [PARTITION BY expr_list] [ORDER BY expr_list]
| Parameter | Description |
| database_name | Database name. The default value is the name of the selected database. |
| table_name | Name of the local table. |
| ON CLUSTER default_cluster | This parameter specifies that a local table is created on each node. The parameter format is fixed at ON CLUSTER default_cluster. |
| name1,name2 | Column names. |
| ENGINE = engine_name() | Table engine type. When creating a table in a dual-replica cluster, you must use the Replicated* engine that supports data replication in the MergeTree series. Otherwise, data is not replicated between replicas, resulting in inconsistent data query results. When using this engine to create a table, set the parameters as follows:
| ORDER BY expr_list | Sorting key, which is mandatory. It can be a tuple of a set of columns or any expression. |
| [PARTITION BY expr_list] | Partition key. The table is usually partitioned by date. You can also use other fields or field expressions. |
Example:
- Create a database. For details, see CREATE DATABASE.
- Use the database.
use demo;
- Create a table named demo.test.
CREATE TABLE demo.test ON CLUSTER default_cluster(`EventDate` DateTime, `id` UInt64)ENGINE = ReplicatedMergeTree('/clickhouse/tables/{shard}/default/test', '{replica}') PARTITION BY toYYYYMM(EventDate) ORDER BY id;
Creating a Table by Copying the Structure of an Existing Table
You can use the following syntax to create a table by copying the structure of a source table:
CREATE TABLE [IF NOT EXISTS] [db.]table_name2 ON CLUSTER default_cluster AS [db.]table_name1 [ENGINE = engine_name];
| db | Database name. The default value is the name of the selected database. |
| table_name1 | Name of the source table from which the structure is copied. |
| table_name2 | Name of the table that you want to create. |
| ON CLUSTER default_cluster | This parameter specifies that a table is created on each node. The parameter format is fixed at ON CLUSTER default_cluster. |
| [ENGINE = engine_name] | Table engine type. If you do not specify a table engine when you create a table, the table engine of the source table is used by default. |
Example:
create database demo;
- Use the database.
use demo;
- Create a data table.
create table demo_t(uid Int32,name String,age UInt32,gender String)engine = TinyLog;
- Copy the table structure.
create table demo_t2 as demo_t;
- View the table structure.
Creating a Table by Specifying a SELECT Clause in a CREATE TABLE Statement
You can use a specified table engine to create a table that has the same structure as the query result of the SELECT clause. The query result of the SELECT clause is populated to the table.
CREATE TABLE [IF NOT EXISTS] [database_name.]table_name ENGINE = engine_name AS SELECT ...
| table_name | Table created using the SELECT statement. |
| ENGINE = engine_name() | Table engine type. |
| SELECT ... | SELECT clause. |
Example:
- Create a table.
CREATE TABLE default.demo1 ON CLUSTER default_cluster( `EventDate` DateTime, `id` UInt64)ENGINE = ReplicatedMergeTree('/clickhouse/tables/{shard}/default/demo1', '{replica}') PARTITION BY toYYYYMM(EventDate) ORDER BY id; - Create a table using the SELECT statement.
create table t3 ON CLUSTER default_cluster ENGINE =MergeTree() order by EventDate as select * from default.demo1;
- Query the structures of tables demo1 and t3.
desc demo1;
The query result shows that the structures of the two tables are the same.
cloudtable-wlr-click-20230730-06-server-1-1 :) desc demo1; DESCRIBE TABLE demo1 Query id: 712f6b91-668d-4f70-b160-aac8e52f63a4 ┌─name──────┬─type─────┬─default_type─┬─default_expression─┬─comment─┬─codec_expression─┬─ttl_expression─┐ │ EventDate │ DateTime │ │ │ │ │ │ │ id │ UInt64 │ │ │ │ │ │ └───────────┴──────────┴──────────────┴────────────────────┴─────────┴──────────────────┴────────────────┘ 2 rows in set. Elapsed: 0.001 sec. cloudtable-wlr-click-20230730-06-server-1-1 :) desc t3; DESCRIBE TABLE t3 Query id: 11b67532-26f0-49c5-b36d-439d45c279bf ┌─name──────┬─type─────┬─default_type─┬─default_expression─┬─comment─┬─codec_expression─┬─ttl_expression─┐ │ EventDate │ DateTime │ │ │ │ │ │ │ id │ UInt64 │ │ │ │ │ │ └───────────┴──────────┴──────────────┴────────────────────┴─────────┴──────────────────┴────────────────┘ 2 rows in set. Elapsed: 0.001 sec.
