Help Center/
CloudTable Service/
User Guide/
Using ClickHouse/
Managing ClickHouse Clusters/
Deleting a ClickHouse Cluster
Updated on 2025-12-29 GMT+08:00
You can delete clusters you will no longer use. Deleting a CloudTable ClickHouse cluster will clear all resources and data related to the cluster. This operation cannot be undone. Exercise caution when deleting a cluster.
- Pay-per-use clusters can be directly deleted. For details, see Deleting a Pay-per-Use ClickHouse Cluster.
- Yearly/monthly clusters cannot be directly deleted. You need to unsubscribe from them (if they have not expired) or release them (if they have expired but have not been renewed). For details, see Unsubscribing from or Releasing a Yearly/Monthly Cluster.
- Log in to the CloudTable console.
- Select a region in the upper left corner.
- In the Operation column of the cluster, click More > Delete.
- In the displayed dialog box, enter DELETE or click Auto Enter, and click OK to delete the cluster.
Figure 1 Confirming the deletion
- In the Operation column of the cluster, choose .
- In the displayed dialog box, enter DELETE or click Auto Enter, and click OK to unsubscribe from or release the cluster.
- On the Unsubscribe page, confirm the cluster information, select reasons for unsubscription, and confirm the unsubscription amount and related fees.
- Select "I've backed up the data or confirmed that the unsubscribed resources are no longer needed." and "I understand that only resources in the recycle bin can be restored after unsubscription". View the recycle bin description and click Unsubscribe.
- Return to the console and check whether the cluster has been unsubscribed from or released.
Parent topic: Managing ClickHouse Clusters
