Updated on 2025-11-19 GMT+08:00
Viewing ClickHouse Cluster Details
You can monitor and manage the clusters you create. In the cluster list, locate the cluster to be viewed and click the cluster name to access the basic information page. You can view the cluster information and network configurations.
Table 1 Cluster information
Cluster Name
Cluster name specified when a cluster is created.
Cluster ID
Cluster ID.
Cluster Status
Cluster status information.
Version
Kernel version of the cluster.
Access Address
Address for accessing the cluster. You can click to copy the access link to the clipboard.
Access Address Port
Port for accessing the cluster.
  • HTTP port: 8123
  • TCP port: 9000
  • HTTPS port: 8443
  • Secure TCP port: 9440
Billing Mode
Billing mode of the cluster.
  • Pay-per-use
  • Yearly/monthly
Created
Time when a cluster is created.
Enterprise Project
You can group related cloud resources (for example, resources used for the same purpose) and manage them by enterprise project.
  • You can delete a user that was authorized to manage an enterprise project if the enterprise's business has changed and the user should not have the permissions to manage the enterprise project.
  • You can delete a user or multiple users.
  • After a user that was authorized to manage an enterprise project is deleted, the user cannot manage the enterprise project. If the user needs to manage the enterprise project, authorize the user to manage the enterprise project again.
Database Engine
A core service used to store, process, and protect data.
Channel Status
Whether secure channels are enabled.
Enable Secure and Non-secure Channels
This parameter is displayed if secure channels are not enabled.
Enable Hot/Cold
"No" indicates that the cold and hot data separation feature is disabled, and "Yes" indicates that the cold and hot data separation feature is enabled.
Storage Resource Name
Name of the cold and hot data separation data storage resource: hot_to_cold.
Cold and Hot Storage Policy
Should a node's total storage capacity surpass the predefined threshold, data stored prior to the threshold is prioritized for migration to cold storage.
Used Cold and Hot Storage Capacity
Used storage capacity of cold data.
Client
Currently, the ClickHouse component has two types of clients: old and new. For a new client, the client identifier displays 'New.' Conversely, for existing clients, the identifier displays 'Old.'
Cluster Storage Mode
Coupled storage and compute
Table 2 Network configuration
Region
Working area of the cluster. Set this parameter when creating a cluster.
AZ
AZ you select during cluster creation.
VPC
VPC you select during cluster creation.
A VPC is a secure, isolated, logical network environment.
Subnet
Subnet you select during cluster creation.
A subnet provides dedicated network resources that are logically isolated from other networks, improving network security.
Security Group
Security group you select during cluster creation.
Table 3 Compute node parameters
Select proper compute specifications based on service requirements. Each specification displays the CPU, memory, and recommended application scenarios of a single node.
Available compute specifications:
  • 8U32G
  • 16U64G
  • 32U128G
  • 32U256G
  • 64U256G
  • 128U512G
Select the disk specifications and capacity of the ClickHouse compute node.
  • Available storage specifications:
    • High I/O
    • Ultra-high I/O
    • Extreme SSD
  • The capacity ranges from 100 GB to 10,000 GB per node.
Nodes
Set the number of nodes in a cluster. The value ranges from 2 to 40.
Table 4 ZooKeeper node parameters
  • 4U8G (This specification is not available for production environments.)
  • 4U16G
  • 8U32G
  • 16U64G
  • 32U128G
The ZooKeeper specifications include only 4U8G (4 vCPUs, 8 GB memory) and 4U16G. In the production environment, you are advised to select 8 vCPUs, 32 GB memory, or higher specifications.
Ultra-high I/O is recommended. Set the disk capacity to 100 GB per node.
Nodes
Number of nodes in a cluster. The default value is 3.
