Updated on 2026-01-29 GMT+08:00
Checking the ClickHouse Cluster Status
You can check the cluster status on the console. In the navigation pane, click Cluster Management. On the Cluster Management page, a cluster list is displayed. If there are a large number of clusters, you can turn pages to view clusters in any state.
Table 1 Cluster management list parameters
Cluster Name
Cluster name specified when a cluster is created.
High Availability
If cluster HA is enabled when a ClickHouse cluster is created, "The cluster can be used only for testing services." is displayed. If it is not enabled, "--" is displayed.
Cluster Status
Cluster status, including Creating, In service, Sub-health, Frozen, and Creation failed.
Task Status
Task status of a cluster.
Database Engine
ClickHouse
Version
Cluster version.
Enterprise Project
You can group related cloud resources (for example, resources used for the same purpose) and manage them by enterprise project.
  • You can delete a user that was authorized to manage an enterprise project if the enterprise's business has changed and the user should not have the permissions to manage the enterprise project.
  • You can delete a user or multiple users.
  • After a user that was authorized to manage an enterprise project is deleted, the user cannot manage the enterprise project. If the user needs to manage the enterprise project, authorize the user to manage the enterprise project again.
Created
Time when a cluster is created.
Billing Mode
Billing mode of a cluster, which can be pay-per-use or yearly/monthly.
Operation
  • Click Monitor to access the CloudTable service monitoring page.
  • Click Specification Expansion, Disk Expansion, or Scale Out to expand the cluster capacity. For details, see Adjusting the Capacity of a ClickHouse Cluster.
  • Click Enable cold and hot data separation to enable the cold and hot data separation feature.
  • Click Delete to delete a cluster.
  • Click Restart to restart the cluster.
  • Choose More > Change to Yearly/Monthly to change the billing mode to yearly/monthly.
  • Click More > Unsubscribe/Release in the Operation column to unsubscribe from the yearly/monthly cluster.
Table 2 Icon description
Icon
Click to view all projects.
Click to refresh the cluster list.
Enter a cluster name in the search box and click to search for it.
Cluster Status
Table 3 Cluster status description
Status
Creating
Indicates that a cluster is being created.
In service
If a cluster is successfully created and can provide services, the cluster status is In service.
Sub-health
If the cluster status cannot be monitored within the specified time, the cluster status changes to Sub-health. Manual intervention is required to recover a cluster that is in Sub-health status. For example, you can restart the cluster to recover the cluster.
Creation failed
Indicates that a cluster fails to be created.
Frozen
If the balance is insufficient for renewing a cluster, the cluster status is Frozen.
If a cluster status is Frozen, you need to renew your subscription and ensure that your account balance is not 0 before unfreezing the cluster.
A frozen cluster is unavailable and its all ECSs are shut down. After being unfrozen, the cluster recovers to the In service state. If you do not renew the cluster before the freeze period ends, the cluster will be deleted.
Task Status
Table 4 Task status description
Status
Deleting
Indicates that a cluster is being deleted.
Restarting
Indicates that a cluster is being restarted.
Scaling out
Indicates that a cluster is being scaled out.
Enabling cold and hot separation
Indicates that cold and hot data separation is being enabled for the cluster.
