Viewing Doris Cluster Details
You can monitor and manage the clusters you create. In the cluster list, locate the cluster to be viewed and click the cluster name to access the basic information page. You can view the cluster information and network configurations.
Parameter | Description |
Cluster Name | Name of a cluster. Set this parameter when creating a cluster. |
Cluster ID | Cluster ID |
Cluster Status | Cluster status information |
Cluster Version | Kernel version of the cluster. |
Access Address | Address for accessing the cluster. You can click |
Billing Mode | Billing mode of the cluster |
Created | Time when a cluster is created |
Database Engine | A core service used to store, process, and protect data. |
Broker Process | Whether to enable the Broker process, which is used to import data for customers. |
Enable Https | If Enable Https is toggled on, you can download the certificates in a secure environment. |
Cluster Storage Mode | The cluster storage mode is coupled storage and compute. |
Enable Interface Authentication | After this function is enabled, account and password authentication is required for REST interfaces in the cluster. NOTE: This parameter is displayed when Enable Https is toggled on. |
Enterprise Project | You can group related cloud resources (for example, resources used for the same purpose) and manage them by enterprise project. NOTE:
Region | Working area of the cluster. Set this parameter when creating a cluster. |
AZ | AZ you select during cluster creation. |
VPC | VPC you select during cluster creation. A VPC is a secure, isolated, logical network environment. |
Subnet | Subnet you select during cluster creation. A subnet provides dedicated network resources that are logically isolated from other networks, improving network security. |
Security Group | Security group you select during cluster creation. |
Compute | Select proper compute specifications based on service requirements. Each specification displays the CPU, memory, and recommended application scenarios of a single node. NOTE: Available compute specifications:
Storage | Select the disk specifications and capacity of the Doris compute node. NOTE:
Nodes | Specify the number of nodes in the cluster. You can add 3 or 5 FE nodes. |
Nodes | Specify the number of nodes in the cluster. You can add 3 to 100 BE nodes. |
