Checking the Doris Cluster Status
The cluster list contains all CloudTable clusters. You can view clusters in various states. If a large number of clusters are involved, navigate through multiple pages to view all of the clusters.
Clusters are listed in chronological order by default, with the in-service clusters displayed at the top.
Parameter | Description |
Cluster Name | Name of a cluster. Set this parameter when creating a cluster. |
HA | When you create a Doris cluster with node specifications less than 8 vCPUs and 32 GB memory, HA is enabled by default, and "The cluster can be used only for testing services." is displayed. If HA is not enabled, "--" is displayed. |
Cluster Status | Cluster status, including Creating, In service, Sub-health, Frozen, and Creation failed. |
Task Status | Task status of a cluster. |
Database Engine | Doris |
Cluster Version | Cluster version. |
Enterprise Project | You can group related cloud resources (for example, resources used for the same purpose) and manage them by enterprise project. NOTE:
Created | Time when a cluster is created |
Billing Mode | Cluster billing mode. |
Access Address (Intranet) | Private network link address. |
Operation |
Icon | Description |
| Click |
| Click |
| Enter a cluster name in the search box and click |
Cluster Status
Status | Description |
Creating | Indicates that a cluster is being created. |
In service | If a cluster is successfully created and can provide services, the cluster status is In service. |
Sub-health | If the cluster status cannot be monitored within the specified time, the cluster status changes to Sub-health. Manual intervention is required to recover a cluster that is in Sub-health status. For example, you can restart the cluster to recover the cluster. |
Creation failed | Indicates that a cluster fails to be created. |
Frozen | If the balance is insufficient for renewing a cluster, the cluster status is Frozen. If a cluster status is Frozen, you need to renew your subscription and ensure that your account balance is not 0 before unfreezing the cluster. NOTE: A frozen cluster is unavailable and its all ECSs are shut down. After being unfrozen, the cluster recovers to the In service state. If you do not renew the cluster before the freeze period ends, the cluster will be deleted. |
Task Status
Deleting | Indicates that a cluster is being deleted. |
Restarting | Indicates that a cluster is being restarted. |
Modifying setting | Indicates that the cluster parameters are being modified. |
Scaling out | Indicates that cluster nodes are being scaled out. |
Expanding disk capacity | Indicates that the disk capacity of the cluster is being expanded. |
Resizing flavor | Indicates that the cluster specifications are being changed. |
