- Billing
- Getting Started
User Guide
HBase User Guide
HBase Cluster Management
- Overview
- Managing Clusters
- Preparing an ECS
- Using HBase
- HBase Cold and Hot Data Separation
- HBase Thrift Server
- HBase Security Channel Encryption
- HBase Batch Data Import
- HBase Monitoring Clusters
- Self-Healing from HBase Hotspotting
- Global Secondary Indexes
ClickHouse User Guide
ClickHouse Cluster Management
- Overview
- Managing ClickHouse Clusters
- Using ClickHouse
- Migrating ClickHouse Data
- ClickHouse User Management
- ClickHouse Role Management
- ClickHouse Slow Query Management
- Configuring Secure Channel Encryption for ClickHouse Clusters
- Application of ClickHouse Cold and Hot Data Separation
- ClickHouse Monitoring Clusters
- Permissions Management
- Audit Logs
- Cluster Log Management
HBase User Guide
Developer Guide
- HBase Application Development Guide
- ClickHouse Application Development Guide
General
- What Services Does a CloudTable Cluster Provide?
- Why Do I Choose CloudTable Service?
- How Do I Prepare for Creating a CloudTable HBase Cluster?
- What Should I Pay Attention to When Using CloudTable Service?
- What Compression Algorithms Are Supported by CloudTable HBase Clusters?
- Can I Stop CloudTable Service?
- Which Programming Languages Are Supported by HBase External APIs in CloudTable?
- How Do I Determine the Number of Faulty RegionServers?
- What Special Characters Does CloudTable HBase Support?
- What Can I Do If the Index Table Does Not Match the Data Table After CloudTable Data Is Deleted?
- What Should I Do If Concurrent Tasks Run Slowly When Python Accesses CloudTable Through Thrift?
- How do I view the TTL attribute of HBase shell?
- Why Are My Server Resources Released?
- How Do I Delete a Cluster?
- How Do I Stop Services and Release Resources?
Connection and Access
- How Do I Access a CloudTable Cluster?
- Can I Use SSH to Access Computing Nodes of CloudTable?
- Why Can't I Access HBase After the ZK Address Is Configured?
- Why Is the Error "Will not attempt to authenticate using SASL (unknown error)" Reported When Connecting to HBase?
- How Do I View the IP Address Corresponding to a Domain Name in a CloudTable Link?
- How Do I Access CloudTable from Other Cloud Services?
- Can I Configure the hbase-site.xml File?
- How Do I Query the Creation Time of a Table in CloudTable HBase?
Data Read/Write
- Is Raw Data Stored in CloudTable HBase?
- Why Can't I Write Data to HBase?
- What Is the Maximum Size of Data Written to the HBase Cluster?
- How Do I Check the Daily Incremental Data in HBase Tables?
- What Should I Do If an Error Is Reported When I Access the CloudTable HBase Cluster?
- How Do I Delete the Backup Table of the ZooKeeper Node in the ClickHouse Cluster?
- What Should I Do If a Database Missing Error Occurs When a Table Is Created in the ClickHouse Cluster?
- Billing FAQs
General
Viewing Audit Logs
After you enable CTS, the system starts recording CloudTable operation logs. Operation records of the last 7 days can be viewed on the CTS management console.
This section includes the following content:
Enabling CTS
A tracker will be automatically created after CTS is enabled. All traces recorded by CTS are associated with a tracker. Currently, only one tracker can be created for each account.
- On the CloudTable management console, choose Service List > Management & Deployment > Cloud Trace Service. The CTS management console is displayed.
- Enabling CTS
If you are a first-time CTS user and do not have any created tackers in the tracker list, enable CTS first. For details, see Enabling CTS in the Cloud Trace Service Getting Started.
If you have enabled CTS, the system has automatically created a management tracker. Only one management tracker can be created and it cannot be deleted. You can also manually create a data tracker. For details, see Managing Trackers > Creating a Tracker in the Cloud Trace Service User Guide.
Disabling the Audit Log Function
If you want to disable the audit log function, disable the tracker in CTS.
- Disable the audit log function by disabling the tracker. To enable the audit log function again, you only need to enable the tracker.
For details about how to enable or disable a tracker, see Disabling or Enabling a Tracker in the Cloud Trace Service Getting Started.
Viewing CTS Logs of CloudTable
- Click Service List on the upper part of the page and choose Management & Deployment > Cloud Trace Service.
- In the navigation pane on the left, choose Trace List.
- In the upper right corner of the trace list, click Filter to set the search criteria.
The following four filter criteria are available:
- Trace Source, Resource Type, and Search By
- Trace Source: Select CloudTable.
- Resource Type: Select All resource types or specify a resource type.
- Search By: Select All or any of the following options:
- Trace name: If you select this option, you also need to select a specific trace name.
- Resource ID: If you select this option, you also need to select or enter a specific resource ID.
- Resource name: If you select this option, you also need to select or enter a specific resource name.
- Operator: Select a specific operator (at user level rather than tenant level).
- Trace Status: Available options include All trace statuses, normal, warning, and incident. You can only select one of them.
- Start Date and End Date: You can specify the time period to query traces.
- Click Query.
- Click
on the left of the trace to be queried to extend its details.
Figure 1 Trace - Locate the row containing the target trace and click View Trace in the Operation column.
Figure 2 Viewing a trace
For details about key fields in the CTS trace structure, see the Trace Structure in the Cloud Trace Service User Guide.
