Updated on 2025-12-18 GMT+08:00
HBase Cluster Monitoring Metrics
Monitoring is critical to ensure CloudTable reliability, availability, and performance. You can monitor the running status of CloudTable servers.
This section describes the metrics that can be monitored by Cloud Eye as well as their namespaces and dimensions.
Namespace
SYS.CloudTable
CloudTable HBase HMaster Instance Monitoring Metrics
Table 1 CloudTable HBase HMaster instance monitoring metrics
Metric ID
Metric Name
Value Range
Unit
Conversion Rule
Monitored Object (Dimension)
Monitoring Interval (Raw Data)
cmdForTotalMemory
Total Memory
Total memory size of the monitored object
> 0
Byte
1024 (IEC)
CloudTable instance node
1 min
cmdProcessCPU
CPU Utilization
CPU utilization of the monitored object
0~100
N/A
1 min
cmdProcessMem
Memory Utilization
Memory utilization of the monitored object
0~100
N/A
1 min
hm_deadregionservernum
Faulty RegionServers
Number of faulty RegionServers in the cluster
≥ 0
Count
N/A
1 min
hm_regionservernum
Normal RegionServers
Number of normal RegionServers in the cluster
≥ 0
Count
N/A
1 min
hm_ritCount
RIT Count
Number of regions in the Region In Transaction (RIT) state in the cluster where the monitored object is located
≥ 0
Count
N/A
1 min
hm_ritCountOverThreshold
RIT Count Over Threshold
Number of regions in the RIT state and reach the threshold in the cluster where the monitored object is running
≥ 0
Count
N/A
1 min
rs_queuecalltime_max
RPC Queue Call Time (Max)
Maximum RPC queue call time
≥ 0
ms
N/A
1 min
rs_queuecalltime_mean
RPC Queue Call Time (Mean)
Mean RPC queue call time
≥ 0
ms
N/A
1 min
nn_percentallused
Disk Utilization Rate
Disk space usage of the cluster
0~100
N/A
1 min
nn_capacityremaining
Disk capacity remaining of cluster
Remaining disk space of the cluster
Depends on the cluster disk capacity.
GB
N/A
1 min
nn_capacityused
Disk capacity used of cluster
Disk space used in the cluster
GB
N/A
1 min
cmdForUsedStorageRate
Ratio of Used Storage Space
Ratio of the used storage space to the total storage space in the cluster
0~100
N/A
1 min
network_throughput_inbound_rate
Inbound Throughput
Inbound data volume over network of each node per second
≥ 0
KB/s
N/A
1 min
network_throughput_outgoing_rate
Outbound Throughput
Outbound data volume over network of each node per second
≥ 0
KB/s
N/A
1 min
disk_throughput_read_rate
Disk Read Throughput
Disk read throughput
≥ 0
Byte/s
1024 (IEC)
1 min
disk_throughput_write_rate
Disk Write Throughput
Disk write throughput
≥ 0
Byte/s
1024 (IEC)
1 min
hmaster instances include hmaster-standby (standby) and hmaster-active (active). When hmaster-active becomes faulty, hmaster-standby becomes active to provide services.
In an HBase cluster, 10% of the disk space is reserved by default. Therefore, the disk alarm value is not equivalent to the raw disk usage percentage.
CloudTable HBase RegionServer Instance Monitoring Metrics
Table 2 lists the monitoring metrics supported by CloudTable HBase RegionServer instances.
Table 2 Monitored CloudTable metrics
Metric ID
Metric Name
Value Range
Unit
Conversion Rule
cmdProcessCPU
CPU Utilization
0~100
N/A
1 min
cmdForTotalMemory
Total Memory
> 0
Byte
1024 (IEC)
1 min
cmdProcessMem
Memory Utilization
0~100
N/A
1 min
Disks Write Rate
Volume of data written to the monitored object per second
≥ 0
Byte/s
1024 (IEC)
1 min
Disks Read Rate
Volume of data read from the monitored object per second
≥ 0
Byte/s
1024 (IEC)
1 min
hm_regionservernum
≥ 0
Count
N/A
1 min
≥ 0
Count
N/A
1 min
Region in transaction count over threshold
≥ 0
Count
N/A
1 min
hm_ritCount
RIT Count
≥ 0
Count
N/A
1 min
rs_requests
Requests Per Second
Number of requests of a RegionServer per second
≥ 0
requests/s
N/A
1 min
rs_regions
Regions
Number of regions of a RegionServer
≥ 0
Count
N/A
1 min
rs_writerequestscount
Write Requests
Number of write requests of a RegionServer
≥ 0
Count
N/A
1 min
rs_readrequestscount
Read Requests
Number of read requests of a RegionServer
≥ 0
Count
N/A
1 min
rs_blockcachehitcachingratio
Hit Cache Block Caching Ratio
Block cache hit caching ratio
0~100
N/A
1 min
rs_blockCacheCountHitPercent
Hit Cache Block Ratio
Block cache hit ratio
0~100
N/A
1 min
rs_getavgtime
Get Delay (Avg)
Average Get operation delay of the RegionServer per unit time
≥ 0
ms
N/A
1 min
rs_putavgtime
Put Delay (Avg)
Average Put operation delay of the RegionServer per unit time
≥ 0
ms
N/A
1 min
rs_deleteavgtime
Delete Delay (Avg)
Average Delete operation delay of the RegionServer per unit time
≥ 0
ms
N/A
1 min
rs_getnumops
Get Operations
Number of Get operations of the RegionServer per unit time
≥ 0
Count
N/A
1 min
rs_putnumops
Put Operations
Number of Put operations of the RegionServer per unit time
≥ 0
Count
N/A
1 min
rs_deletenumops
Delete Operations
Number of Delete operations of the RegionServer per unit time
≥ 0
Count
N/A
1 min
≥ 0
ms
N/A
1 min
≥ 0
ms
N/A
1 min
rs_flushtime_mean
Flush Time(Mean)
Mean time of flush
≥ 0
ms
N/A
1 min
rs_compactionqueuesize
Compaction Queue Size
Point in time length of the compaction queue. The number of Stores for compaction in the RegionServer.
≥ 0
Count
N/A
1 min
rs_flushqueuesize
Flush Queue Size
Flush queue size
≥ 0
Count
N/A
1 min
rs_compactionscompletedcount
Compaction Count
Count of compaction
≥ 0
Count
N/A
1 min
rs_flushtimeops_num
Flush Operation Count
Count of flush operation
  • Flush Operation Count belongs to a counter type. When its value reaches the upper limit, the counter wraps around and starts counting from zero.
  • After a cluster is restarted, Flush Operation Count will also be cleared and recalculated.
≥ 0
Count
N/A
1 min
rs_blockcacheevictedcount
Discarded Cache Blocks
Block cache evict count
≥ 0
Count
N/A
1 min
rs_syncTime_max
Sync WAL Time(Max)
Maximum time it took to sync the WAL
≥ 0
ms
N/A
1 min
rs_syncTime_mean
Sync WAL Time(Mean)
Mean time it took to sync the WAL
≥ 0
ms
N/A
1 min
dn_byteswritten_speed
Bytes written per second
Bytes written per second of the node
≥ 0
Byte
1024 (IEC)
1 min
dn_bytesread_speed
Bytes read per second
Bytes read per second of the node
≥ 0
Byte
1024 (IEC)
1 min
rs_numActiveHandler
Number of RegionServer Active Handlers
Number of active RegionServer handlers (total number of handlers for processing user table requests, meta table requests, and replication requests)
≥ 0
Count
N/A
1 min
rs_numActiveGeneralHandler
Number of RegionServer Active Handlers for Processing User Table Requests
Number of active RegionServer handlers for processing user table requests
≥ 0
Count
N/A
1 min
rs_scanTime_p999
99.9th Percentile of the Scan Operation Delay
99.9th percentile of the RegionServer Scan operation delay
≥ 0
ms
N/A
1 min
rs_syncTime_p999
99.9th Percentile of the WAL Sync Operation Delay
99.9th percentile of the RegionServer WAL Sync operation delay
≥ 0
ms
N/A
1 min
rs_Get_99th_percentile
99th Percentile of the Get Operation Delay
99th percentile of the RegionServer Get operation delay
≥ 0
ms
N/A
1 min
rs_Put_99th_percentile
99th Percentile of the Put Operation Delay
99th percentile of the RegionServer Put operation delay
≥ 0
ms
N/A
1 min
rs_Delete_99th_percentile
99th Percentile of the Delete Operation Delay
99th percentile of the RegionServer Delete operation delay
≥ 0
ms
N/A
1 min
rs_Get_999th_percentile
99.9th Percentile of the Get Operation Delay
99.9th percentile of the RegionServer Get operation delay
≥ 0
ms
N/A
1 min
rs_Put_999th_percentile
99.9th Percentile of the Put Operation Delay
99.9th percentile of the RegionServer Put operation delay
≥ 0
ms
N/A
1 min
rs_Delete_999th_percentile
99.9th Percentile of the Delete Operation Delay
99.9th percentile of the RegionServer Delete operation delay
≥ 0
ms
N/A
1 min
Dimension
Key
Value
cluster_id
CloudTable cluster ID.
To obtain the value, go to the cluster management page, click the cluster name, access its details page, and obtain the cluster ID in the cluster information area.
instance_name
Name of a CloudTable cluster node.
To obtain the value, go to the cluster management page, click the cluster name, access its details page, and obtain the value of instance_name.
