Updated on 2025-12-29 GMT+08:00
Deleting an HBase Cluster
If a cluster is no longer needed, you can delete, unsubscribe from, or release the cluster. Deleting, unsubscribing from, or releasing a CloudTable cluster will clear all resources and data related to the cluster. This operation cannot be undone. Exercise caution when deleting a cluster.
  • A cluster in the Scaling out state cannot be deleted. You need to delete it after the scale-out is complete.
  • If your cluster is in arrears, this function may be unavailable. Please top up your account in time.
Deleting an HBase Pay-per-Use Cluster
  1. Log in to the CloudTable console.
  2. Select a region in the upper left corner.
  3. In the Operation column of the cluster, choose More > Delete.
  4. In the displayed dialog box, enter DELETE or click Auto Enter, and click OK to delete the cluster.
    Figure 1 Confirming the deletion
Unsubscribing from or Releasing a Yearly/Monthly Cluster
  3. In the Operation column of the cluster, choose More > Unsubscribe/Release.
  4. In the displayed dialog box, enter DELETE or click Auto Enter, and click OK to unsubscribe from or release the cluster.
  5. On the Unsubscribe page, confirm the cluster information, select reasons for unsubscription, and confirm the unsubscription amount and related fees.
  6. Select "I've backed up the data or confirmed that the unsubscribed resources are no longer needed." and "I understand that only resources in the recycle bin can be restored after unsubscription". View the recycle bin description and click Unsubscribe.
  7. Return to the console and check whether the cluster has been unsubscribed from or released.
