Checking the HBase Cluster Status
You can check the cluster status on the console. In the left navigation, click Cluster Management. On the Cluster Management page, a cluster list is displayed. If there are a large number of clusters, you can turn pages to view clusters in any state.
Clusters are listed in chronological order by default, with the latest cluster displayed at the top. Table 1 and Table 2 provides parameters and icons in the cluster list.
| Parameter | Description |
| Cluster Name | Name of a cluster. Set this parameter when creating a cluster. |
| Cluster Status | Cluster status, including Creating, In service, Sub-health, Frozen, and Creation failed. |
| Task Status | Task status of a cluster. For details, see Table 4. |
| Database Engine | HBase |
| Cluster Version | Cluster kernel version |
| Enterprise Project | You can group related cloud resources (for example, resources used for the same purpose) and manage them by enterprise project. NOTE:
| Created | Time when a cluster is created |
| Billing Mode | The cluster billing mode can be pay-per-use or yearly/monthly. |
| ZK Link (Intranet) | ZooKeeper address |
| Operation |
| Icon | Description |
| Click |
| Enter a cluster name in the search box and click |
| Click |
Cluster Status
| Status | Description |
| Creating | Indicates that a cluster is being created. |
| In service | If a cluster is successfully created and can provide services, the cluster status is In service. |
| Sub-health | If the cluster status cannot be monitored within the specified time, the cluster status changes to Sub-health. Manual intervention is required to recover a cluster that is in Sub-health status. For example, you can restart the cluster to recover the cluster. |
| Creation failed | Indicates that a cluster fails to be created. |
| Frozen | If the balance is insufficient for renewing a cluster, the cluster status is Frozen. If a cluster status is Frozen, you need to renew your subscription and ensure that your account balance is not 0 before unfreezing the cluster. NOTE: A frozen cluster is unavailable and its all ECSs are shut down. After being unfrozen, the cluster recovers to the In service state. If you do not renew the cluster before the freeze period ends, the cluster will be deleted. |
Task Status
| Deleting | Indicates that a cluster is being deleted. |
| Restarting | Indicates that a cluster is being restarted. |
| Enabling Thrift Server | Indicates that the Thrift Server is being enabled in the cluster. |
| Disabling Thrift Server | Indicates that the Thrift Server is being disabled in the cluster. |
| Scaling out | Indicates that cluster nodes are being scaled out. |
| Disk expanding | Indicates that the disk capacity of the cluster is being expanded. |
| Resizing Flavor | Indicates that the cluster specifications are being changed. |
