Updated on 2025-08-28 GMT+08:00
Viewing Metrics
The Cloud Eye service monitors operating statuses of CloudPond.
You can view the monitoring metrics of CloudPond on the Cloud Eye management console.
It can take a period of time to obtain and transfer the monitoring data. Wait for a while and then check the data.
- Log in to the Cloud Eye console.
- In the navigation pane on the left, choose Cloud Service Monitoring > Intelligent EdgeSite IES.
- Locate the row that contains the edge site you purchased and click View Metric in the Operation column to check detailed monitoring.
Parent topic: Monitoring Data
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
