Supported Metrics
This section describes the namespace, monitoring metrics, and monitoring dimensions of CloudPond. You can use the management console or the APIs provided by Cloud Eye to query CloudPond metrics.
Cloud Eye can monitor dimensions nested to four levels (levels 0 to 3) at most. Level 3 is the most granular level. For example, if the dimension information of a metric is site_id, storage, site_id indicates level 0 and storage indicates level 1.
Namespace
SYS.IES
Monitoring Metrics
| ID | Metric | Description | Value Range | Unit | Conversion Rule | Dimension | Monitoring Period (Raw Data) |
| connect_status | Connection status | Cloud-edge network status of the monitored edge site
| ≥ 0 | - | N/A | site_id | 1 min |
| vcpu_util | vCPU usage | vCPU usage of the monitored edge site Formula: Number of used vCPUs of the edge site/Total number of vCPUs of the edge site | ≥ 0 | % | N/A | site_id | 5 min |
| mem_util | Memory usage | Memory usage of the monitored edge site Formula: Memory used of the edge site/Total memory of the edge site | ≥ 0 | % | N/A | site_id | 5 min |
| vcpu_used | Used vCPUs | Number of vCPUs used by the monitored edge site | ≥ 0 | count | N/A | site_id | 5 min |
| vcpu_total | Total vCPUs | Total number of vCPUs of the monitored edge site | ≥ 0 | count | N/A | site_id | 5 min |
| mem_used | Used memory | Memory usage of the monitored edge site | ≥ 0 | GiB | N/A | site_id | 5 min |
| mem_total | Total memory | Total memory of the monitored edge site | ≥ 0 | GiB | N/A | site_id | 5 min |
| capacity_used | Used storage | Storage usage of the monitored edge site | ≥ 0 | GiB | N/A | site_id | 5 min |
| capacity_total | Total storage | Total storage of the monitored edge site | ≥ 0 | GiB | N/A | site_id | 5 min |
| vcpu_used_perflavor | ECS – Used vCPUs of an instance type | Number of vCPUs used by an instance type | ≥ 0 | count | N/A | site_id, vmflavor | 5 min |
| vcpu_total_perflavor | ECS – Total vCPUs of an instance type | Total number of vCPUs of an instance type | ≥ 0 | count | N/A | site_id, vmflavor | 5 min |
| vcpu_util_perflavor | ECS – vCPU usage of an instance type | vCPU usage of an instance type Formula: Number of used vCPUs of an instance type/Total number of vCPUs of the edge site | ≥ 0 | % | N/A | site_id, vmflavor | 5 min |
| mem_used_perflavor | ECS – Used memory of an instance type | Memory used by an instance type | ≥ 0 | GiB | N/A | site_id, vmflavor | 5 min |
| mem_total_perflavor | ECS – Total memory of an instance type | Total memory of an instance type | ≥ 0 | GiB | N/A | site_id, vmflavor | 5 min |
| mem_util_perflavor | ECS – Memory usage of an instance type | Memory usage of an instance type Formula: Used memory of an instance type/Total memory of the edge site | ≥ 0 | % | N/A | site_id, vmflavor | 5 min |
| capacity_used_perblockstor | EVS – Used storage | Used storage of an EVS disk type | ≥ 0 | GiB | N/A | site_id, storage | 5 min |
| capacity_total_perblockstor | EVS – Total storage | Total storage of an EVS disk type | ≥ 0 | GiB | N/A | site_id, storage | 5 min |
| capacity_util_perblockstor | EVS – Storage usage | Storage usage of an EVS disk type Formula: Used storage/Total storage of the edge site | ≥ 0 | % | N/A | site_id, storage | 5 min |
| object_capacity_used | Object Storage Resource Usage | Used storage of all OBS buckets in a CloudPond instance | ≥ 0 | GiB | 1024 | site_id | 5 min |
| object_capacity_available_total | Total Available Object Storage Capacity | Total available storage of all OBS buckets in a CloudPond instance | ≥ 0 | GiB | 1024 | site_id | 5 min |
| object_capacity_util | Object Storage Resource Utilization | Percentage of the used storage capacity to the total available storage capacity of all OBS buckets in a CloudPond instance. Formula: Used object storage/Total available object storage × 100% | ≥ 0 | % | N/A | site_id | 5 min |
For monitoring metric capacity_total_perblockstor (the total available capacity of EVS disks at a site), its dimension information is site_id, storage. This indicates that dimension site_id is level 0 and storage is 1.
- To query a single monitoring metric using an API, the storage dimension information used is as follows:
dim.0=site_id,3d65c1ac-9a9f-4c5f-a054-35184a087bb2&dim.1=storage,SAS
3d65c1ac-9a9f-4c5f-a054-35184a087bb2 and SAS are the values of site_id and storage, respectively. For details about how to obtain the dimension values, see the "Dimensions" table below.
- To batch query monitoring metrics using an API, the storage dimension information is used as follows:
"dimensions": [
"name": "site_id",
"value": "3d65c1ac-9a9f-4c5f-a054-35184a087bb2"
"name": "storage",
"value": "SAS"
Dimensions
| Key | Value |
| site_id | Edge site ID. |
| vmflavor | ECS flavor |
| storage | Storage type |
