- Getting Started
User Guide
- CloudPond Console Overview
- Edge Site
- Network Connectivity
- Cloud Resources
- Monitoring Data
- Enterprise Project Management
- Quota Adjustment
- Auditing
- Popular Questions
- CloudPond Overview
- Security
- Billing
- Region and Edge site
Rack Installation
- How Do I Know Whether My On-premises Data Center Meets the CloudPond Location Requirements?
- Can I Install Third-Party Devices in the Racks?
- Who Will Install the Hardware and Software After the Racks Are Delivered to the Location?
- What Do I Need to Do Before, During, and After an Edge Site Is Deployed?
- O&M
- Upgrade and Capacity Expansion
- Best Practices
Viewing Cloud Resource Usages
View the usages of compute resources (vCPUs and memory) and storage resources used at the edge site on the CloudPond console after you provision cloud services.
See Cloud Resource Usage Metrics for more details about the metrics.
- Click
in the upper left corner and select a region.
- Click
. In the service list displayed, choose Content Delivery & Edge Computing > CloudPond, or enter CloudPond in the search box.
The dashboard is displayed.
- In the left navigation pane, choose Edge Sites.
- View the vCPU, memory, and storage resource usages.
- If the status of the edge site is Pending deployment, Deploying, or Unavailable, -- is displayed.
- When the resource usage is less than 50%, the bar is green. When the resource usage is greater than or equal to 50% and less than 80%, the bar is orange. When the resource usage is greater than or equal to 80%, the bar is red.
When the progress bar is red, apply forcapacity expansion or delete unnecessary resources in a timely manner.
- Click the edge site name and view resource usage details.
You can view the following information in the Resource and Available Cloud Server Resources area:
- Quantity and usage of each resource
- Computing resource types and the quantity and usage of each type of resources
