Cloud Resource Usages
CloudPond allows you to view the usage of compute resources (vCPUs and memory) and storage resources used at your edge site to help you make full use of cloud resources.
| Metric | Meaning | Value Range | Monitored Object |
| vCPU usage | Displays the ratio of the vCPUs of all flavors used by the edge site to the total purchased vCPUs. Unit: percent (%) | 0–100% | Edge site |
| Memory usage | Displays the ratio of the memory of all flavors used by the edge site to the total purchased memory. Unit: percent (%) | 0–100% | Edge site |
| Storage resource usage | Displays the ratio of the storage resources used by the edge site to the total purchased storage resources. Unit: percent (%) | 0–100% | Edge site |
