- Getting Started
User Guide
- CloudPond Console Overview
- Edge Site
- Network Connectivity
- Cloud Resources
- Monitoring Data
- Enterprise Project Management
- Quota Adjustment
- Auditing
- Popular Questions
- CloudPond Overview
- Security
- Billing
- Region and Edge site
Rack Installation
- How Do I Know Whether My On-premises Data Center Meets the CloudPond Location Requirements?
- Can I Install Third-Party Devices in the Racks?
- Who Will Install the Hardware and Software After the Racks Are Delivered to the Location?
- What Do I Need to Do Before, During, and After an Edge Site Is Deployed?
- O&M
- Upgrade and Capacity Expansion
- Best Practices
Managing Local Gateway Route Tables
Viewing a Local Gateway and Its Route Table
After hardware and software installation is complete, you can view the local gateway and local gateway route table of the edge site on the CloudPond console.
Log in to the CloudPond console. In the left navigation pane, choose Local Gateways. Locate the local gateway and view its details. The local gateway name and ID, edge site name and ID, and AZ are generated by the system.
Each edge site can have only one local gateway.
Viewing a Local Gateway Route Table
Log in to the CloudPond console. In the left navigation pane, choose Local Gateways. Locate the local gateway whose route table you want to view and click Manage Route Table in the Operation column. The name and ID of the route table are generated by the system.
Each local gateway can have only one route table.
Disassociating a VPC from a Local Gateway Route Table
Disassociate a VPC from a local gateway route table if you no longer need the VPC.
Log in to the CloudPond console. In the left navigation pane, choose Local Gateways. Locate the local gateway whose route table you want to manage and click Manage Route Table in the Operation column. On the Associated VPCs tab page, locate the VPC you want to disassociate from the route table, and click Disassociate in the Operation column.
Disassociating the VPC may interrupt services. Exercise caution when performing this operation.
Deleting Routes from a Local Gateway Route Table
Delete routes that are no longer needed from the local gateway route table.
Contact Huawei Cloud O&M team to delete the CoIP.
Deleting routes may interrupt services. Exercise caution when performing this operation.
